A Tesla or even an outlander with a boat trailer with 150kwh of batteries under the boat will probably do it. And it will also depend on where you are driving from.
As for the electric truck with a kerb weight 2670kg sounds a bit light. Even with Tesla batteries 180kwh will be 1100kg of batteries.
The specs say:
Trailer Weight Rating (lbs): 5000kg
I'm guessing it actually means 5000lbs, or 2267kg. Even this is a very good towing capacity.
And 330 litres in the froot!
And AC power outlets!
