Years ago, there were these E-max sport scooters which were really crap. They came with lead cells which were heavy and lousy, and failed after a fairly short period. Patrick Finnegen and the guys at EV Shop in Balcatta had a few which I converted to lithium, as well as a WA branch field day where we took a dilapidated scooter under our wing and treated it to some lithium.
They went better, but really, the scooters themselves were still pretty ordinary. The wheels were too small to handle any bumps, a tall person would accidentally turn the scooter off by bumping the key with their knee, and they wouldn't ride out of sight on a dark night. So I bought all three scooters which had under-utilised 20 Ah LFP cells and decided to make a home energy storage system. The three scooters gave me 96 cells, and I ended up buying some new ones from EV-Power to bring this up to 144 (~9 kWh).
If one gets paid 7 cents a kWh to export, it makes sense to use all your power when the sun shines; charge an EV or run the hot water system. If you can't do either of these because you live in a rental and ride your EV to work, well, you really need a battery.
I decided to make the 'power cabinet' as universal as possible. Starting with a steel frame cabinet to fit cells on the lower and middle shelves, and enough room for the charger/inverter in the upper shelf. The top is clear for me to pile crap on top of.
The cells were terminated using laser cut 5000-series aluminium. I made the holes 6 mm to account for the invariable irregularities, despite the bolts being M5. Also, since the busbars were touching aluminium terminals below, I didn't put any conductive grease on them, but perhaps I should have? Anyway, the wooden shelves made it easier to terminate with a torque setting on the drill, and then I could lower the battery trays onto the shelves.
To join the two 8s9p shelves, I used 8 parallel lengths of 8-gauge wire. This ensures the current path is evenly distributed across the cells, rather than having one cell at the end taking all the current at its terminal.
There is a main isolation switch, 125 A fuse, busbars for running any 48 volt loads should you want to (lights, fridge etc) and a shunt for measuring current. Two DC leads come from the battery - one for the charger which is a 1600 W 48 volt lithium charger and one for the inverter @bga kindly loaned me. The inverter is an PIP4048 which has a maximum DC input from solar of 120 volts - too high for two panels in series, and too low for three in series. I believe the later models now use 145 V as the maximum MPPT voltage.
The charger is set to charge from mains when the GPO timer ticks over to 10 am, and ticks off at 3 pm. This is more than enough time to fully charge the battery. I'm using 16 EV-Power battery balances to ensure the cells never go over 3.55 V per cell. I will eventually put a more detailed BMS on, but for now the PIP4048 inverter is set to shut off at 46 volts which is pretty much empty give or take some safety margin. I never let it run that low anyway.
So now I can come home at night, plug the scooter charger in to the inverter and put some bottled sunshine into the bike. Never any more than about 4 kWh on a big day - typically 3 kWh. I can do this once every couple of days. The timer ensures that it's only charged while the sun shines. It doesn't tun the house or anything like that - but it would be able to handle an 8 kW load if it needed to.
So, how are you going to set your battery up?
