Volt Interest Group
Post by g4qber » Wed, 19 Mar 2014, 14:51
plugged in & out 3x
Post by g4qber » Mon, 14 Apr 2014, 13:08
had to reset @ meter box.
Post by g4qber » Sat, 17 May 2014, 20:13
:roll: 2011 i-MiEV - 156 kms October 2018
Post by g4qber » Thu, 11 Sep 2014, 00:47
Post by g4qber » Sun, 21 Dec 2014, 23:03
Post by g4qber » Tue, 24 Mar 2015, 14:45
Post by antiscab » Tue, 24 Mar 2015, 16:25
2011 Blade Electron mk6
2007 vectrix - 145'000km
1998 Prius - needs batt
Post by g4qber » Mon, 31 Oct 2016, 13:46
Peter C in Canberra
Real Name: Peter Campbell
Post by Peter C in Canberra » Sun, 14 Jan 2018, 07:52
Post by g4qber » Sun, 14 Jan 2018, 11:53
Hi peter C
Peter C in Canberra
Post by Peter C in Canberra » Sat, 12 May 2018, 11:17
Any solution yet?
rhills
Real Name: Rob Hills
Post by rhills » Sat, 12 May 2018, 14:12
Hi Peter,
HTH,
Jul 2014 - Jun 2018
Total Petrol: 586.8L
ODO: 42885
Av Consumption: 1.37 L/100km
Post by g4qber » Sat, 12 May 2018, 20:30
Solution
Peter C in Canberra
Post by Peter C in Canberra » Sun, 13 May 2018, 14:26
Hi Peter,
HTH,
I use the Volt EVSE with my Mitsubishi iMiEV and it has never tripped. At home I use the iMIEV EVSE for both cars and the Volt trips just often enough to be annoying but the iMiEV never trips. My conclusion, like the one earlier in the thread, is that it is the Volt itself, not the Volt EVSE that is causing RCDs to trip itermittently.
rhills
Post by rhills » Sun, 13 May 2018, 15:40
Hi Peter,
My experience is obviously quite different from yours as we don't own a Volt. Maybe our EVSE (which I purchased from @g4qber with full disclosure about the issues he'd experienced with it) is faulty and it's a different problem from yours...
Jul 2014 - Jun 2018
ODO: 42885
Peter C in Canberra
Post by Peter C in Canberra » Mon, 14 May 2018, 20:53
Any solution yet? ... I am wondering if it is worth getting a portable in-line RCD cord? My thought is to have that trip where it affects only the car and I can readily reset it to have another go at starting charging. With luck it might be slightly more sensitive than others so it goes first?
I got a 2m cord from Jaycar with an RCD device in-line and experimented today. Sometimes it tripped, sometimes it didn't but the house RCD always tripped when the cord tripped. Sadly, the cord tripping did not save a trip to the meter box to reset the RCD there.
Post by g4qber » Tue, 15 May 2018, 05:16
I have a solution.
Possibly
This is what I did.
Peter C in Canberra
Post by Peter C in Canberra » Tue, 15 May 2018, 06:39
I have a solution. Buy the smallest wallbox unit you can find...And wire is up for luggable use...My layperson’s Reason being that wallboxes don’t have rcds.
Post by g4qber » Tue, 15 May 2018, 07:48
Completely agree with you.
I’m not an electrician
But
Peter C in Canberra
Post by Peter C in Canberra » Tue, 15 May 2018, 08:57
But The issue may be having 2 rcds in series...
Post by g4qber » Tue, 15 May 2018, 16:11
Peter C in Canberra
Post by Peter C in Canberra » Tue, 15 May 2018, 16:18
Post by g4qber » Tue, 15 May 2018, 16:33
Peter C in Canberra
Post by Peter C in Canberra » Tue, 15 May 2018, 17:08
Post by g4qber » Tue, 15 May 2018, 19:50
