Looking for a BLDC, PMSM of at least 20kW continuous. Needs to be IP65 or better as its in a small offroad vehicle.
Looking for:
Nissan Leaf Motor, Motoenergy ME1616 or ME1507, Parker GVM (Brammo) or something similar. Liquid cooling ideal, but would consider air cooled.
20kW+ Motor wanted..
- Real Name: Piers Morton
- jonescg
- Real Name: Chris Jones
Re: 20kW+ Motor wanted..
https://evparts.com.au/motors/evkit-me1507-100v-ev.html
These might be a good place to start. Parker GVM do a wide range of motors too but they might be a bit too heavy for your application.
- Real Name: Michael Crowley
Depending on the application, the electric rear motor in some Toyota/Lexus hybrids (part # Q211) is approximately 50kW peak, is air cooled and has an integrated differential. You should be able to buy one locally from a wrecker from a Lexus RX400h. Even if from a high mileage vehicle it should be in good condition as they are an on demand motor so only run during initial acceleration and when traction requires. Video of the unit operation and components here https://www.youtube.com/watch?v=KuR0cihFAvQ
The Q211 is a possibility if anyone has one for sale
Found an ME1507, thankyou GUMTREE
- Richo
- Real Name: Richard
Good find!
