Oversized RC BLDC Outrunners
Post by Richo » Thu, 16 Nov 2017, 13:01
Well I was having a look around and the biggest RC BLDC and came across these 2:
35kW 400A 120V 3kg AUD$1600 at your door incl controller
50kW 500A 120V 6kg AUD$1825 at your door incl controller
Trade in you car for a plane :lol:
https://www.aliexpress.com/item/Flier-b ... eLevelAB=0
https://www.aliexpress.com/item/Hot-sal ... eLevelAB=0
Re: Oversized RC BLDC Outrunners
Post by Adverse Effects » Thu, 16 Nov 2017, 14:12
already been done by a kid
goingbush
Real Name: Don
Post by goingbush » Thu, 16 Nov 2017, 18:38
Awesome video, Thanks for sharing . I'm an R/C tragic all glowplugs tho never got into Electrics, that will change once my EV is done !!
Post by Adverse Effects » Fri, 17 Nov 2017, 03:54
hehe i have a 1208mm hex-a-copter that swings 18" CF props and can lift just short of 14Kg of payload :-) and its just a toy hahaha
Hex = 6 motors and 1208mm is the distance between opposite motor shafts
Post by Richo » Fri, 17 Nov 2017, 12:32
Swwweeet.
14kg is an impressive amount to carry around!
Just out of interest how long(minutes) will it fly unloaded and with what size battery?
Post by Adverse Effects » Fri, 17 Nov 2017, 22:19
38 min with 2 x 6S 5600mah (22V 5.6Ah) and i get hot motors and flat battery's in just over 3 min at carrying full load and i dont do that often because it hurts my unit BIG time
