I heard a noise, then the light came on on the dash that indicates the thermal switch on the motor has closed. This is a switch in the motor somewhere that I connected to a likely-looking disused dash light.
I coasted to a stop and opened the bonnet. Could smell a burning smell. Tried to run the motor in neutral but it did not turn at all.
Once I was home I took off some covers and had a look. Found that one of the four sets of brushes was lop-sided, and one of the brushes was disconnected.
The motor is a Kostov.
1st photo is of the two brushes I took out (they sit next to each other). The longer one is more or less how it should be, but the other one has been warn right down. It was jammed in its cradle on an angle. You can't see it from the photo, but the lug on the wires on that one is quite bent as if it had been hit, or probably pulled by the brush.
Next photo shows the thing the brushes sit on, as well as the bracket for the brushes I removed. I don't think there is any damage here. I felt for score marks with my finger and didn't feel anything.
The next photo shows one of the other three sets of brushes. They all look undamaged as far as I can see.
The last photo is of the bracket again. It looks a bit lopsided, but so do the others.
I've taken the brushes out to see if my local motor re-winds workshop can supply replacements.
Any advice is welcomed.
What could cause this?
Do I need to replace all the brushes at once?
Am I likely to get replacements locally, if not where would I go?
What do I need to know about installing new brushes?
Is there any other damage I should be looking for while I'm in here?
