and the new project car.
2014 Outlander PHEV Aspire. complete less right front strut and front bumpers and headlight.
everything else is there, and working, obviously there are errors when you turn it on, ABS and Stability errors with the missing front wheel, and collision mitigation system errors with the missing front radar.
everything else is there, battery is fine, and still 75% charged, engine, generator, both motors, and the leather interior.
We have already changed the electric heated and adjusted seats into my cloth interior PHEV, the electric adjustment works fine, the complete heated seat system is already there, switches swapped into my car, switches are powered and light up with the usual interior lighting, just need to tell the ECU that it now has electric heated seats... need a M.U.TIII programmer for that...
This will be a long term project, to get into the software, next to modify the battery for more capacity, if that is successful, then install upgraded battery into the road going, then use the spare battery as a powerwall, charge it from Solar, then use its capacity to charge my car without drawing from the grid at night, and eventually, install the running gear, Battery, motors, generator and engine into another car.... unsure of what that will be yet...
