Obsolete Thread
- EV2Go
- Real Name: Paul
EV2Go's - Lithium Powered Trike
- EV2Go
- Real Name: Paul
You beat me to it, I was about to say you if you can keep the battery pack part of the rear frame then the issue of cable movement/twist is negated.
Each design has its merits. Your current design allows for the tilt of the whole trike so you may gain something from the CoG change as long as you can eliminate or reduce bump steer when at full tilt.
You probably have seen this already, but the tilting trike at the top of this page is the sort of idea I was going for:
https://en.wikipedia.org/wiki/MEV_Ltd
- EV2Go
- Real Name: Paul
True. It's not a good example of what I was trying to explain either, so I've taken the liberty of copying one of the earlier pictures you posted and have tried to edit it to get across the idea I have:
Where I've drawn in red would be the "rear" frame that the motor, diff, rear suspension etc mount to. The "front" frame would be all the remaining green frame of your existing design and it would attach to the new "rear" frame at two points, one bearing in the front and one bearing in the rear. This would allow the green frame to pivot around the red frame.
I hope this makes sense.
- EV2Go
- Real Name: Paul
- EV2Go
- Real Name: Paul
What about passing the cables from the controller to the motor through the bearing centre on the rear bearing? There would be minimal movement in this scenario and you would just need to ensure the cables were routed in the rear frame so as not to foul on the suspension components.EV2Go wrote:The battery cables go from the main pack at the front to the controller at the back. No problems there but when you try route the cable from the controller to the motor is where all hell breaks loose.
- EV2Go
- Real Name: Paul
- EV2Go
- Real Name: Paul
Isn't that what you're trying to achieve though? If the trike hits a bump with one wheel that side's suspension moves up, this in turn pushes on the rear frame which can pivot independantly of the front frame via the outside bearings. This would mean that the bump is absorbed without changing the tilt of the front frame / rider.EV2Go wrote:If suspension was applied to diff, it would take the path of least resistance and try turn at the outside bearings.
- EV2Go
- Real Name: Paul
- EV2Go
- Real Name: Paul
- EV2Go
- Real Name: Paul
All valid points.
Unfortunately I'm out of ideas for now. I've been looking at some of the other leaning trike designs around the web and I'm yet to find one that doesn't use an IRS setup, like the following:
http://www.mysterydesigns.com/tiltster.php
- Adverse Effects
- Real Name: Adverse Effects
- EV2Go
- Real Name: Paul
- EV2Go
- Real Name: Paul
- Adverse Effects
i am sort of mobile as in i have a car and its running (if you can call it that hahaha)
i may have a "gift" for you if you want it and it will be for the CNC Mill after one of the jobs i have coming up but i'll have to see if it comes off
as for the CNC i would love to see it running
- Real Name: Glenn Marks
EV2GO I remember you discussing the design of this back diff tilt( a couple of years ago) and disagreeing with your original plan, but this, your latest plan will work and is as simple as it possibly could be. As you say if the suspension is air, then it allows tilt. If the movement in the shocks (springs?) is too short then just move the anchor point closer to the centre of the diff.
Just one thing to watch is the batteries centre of gravity needs to be inline with the tit axis otherwise it will want to fall to one side all the time unless the centre of gravity is lower than the tilt axis, then it will resist tilting.
I am referring to the design with the bar going over the diff with the whats linkage.
Regards
Glenn Marks
Glenn Marks
The leaf spring would work but the air suspension idea would be adjustable and you could have a restrictor in the line that joins the 2 together to give some resistance for tilt. In other words highly tuneable making it possible to get it just right.
Regards
Glenn Marks
Glenn Marks
- EV2Go
- Real Name: Paul
- EV2Go
- Real Name: Paul
EV2Go wrote: Imagine this blue bar was the shock (or even rigidly mounted) which effectively stops the diff from rotating freely on the front and rear bearings.
If there was a second set of free moving bearings sitting just outside the inside bearing, the kinetic energy from the road bump would see the shock as a decent form of resistance, and say that's too hard for me to move and treat that whole unit like it was locked up (just like a solid bar would do).
That bump energy would then see the freely rotating outside bearings just outside those inside bearings and say hey it's much easier if I just tilt the diff from this point instead.
Hence the problem you can't have both an actively returning suspension and tilt, it has to be one or the other.
The other alternative is to not restrict the bearings (i.e. no shock) and that would allow the tilt and the diff movement but no active pressure for the wheel return.
you need to be careful where you mount your shocks on a nine inch, I broke one in half on rough road it cracked on the weld from Banjo to axle tube and broke in half. Nothing a big gusset did not fix.
2 x PIP4048HS
15S2Px3 45x90Ah TS and
45x100Ah CALB
With 6Kw Solar Offgrid
6x175W BP 1Kw Si Offgrid
28x60W Thin film Offgrid
18x185W 2Kw Si Offgrid
72x82W gridtied CMS2000 2kw north,2Kw East,2Kw west.
45x100Ah CALB
