EV first timer
Riverend
EV first timer
Post by Riverend »
Hi EV-ers - I’ve been bitten by the EV bug and looking seriously in to the ways I could take to convert to Electric drive. The vehicle will probably be a Rav 4 Honda CRV or Suzi Vitara for ground clearance as we do quite a bit of dirt road commuting. Tending to an Ac 3 phase motor 11 or 15kw 4 pole coupled directly to the tail shaft. (We are Grape growers and have all sorts of 3 phase motors. An electric Quad or motor bike sounds good too!)
Batteries to be Litium Ion, which while expensive seem to be the best long term choice. I’m still coming to grips with the controller - does it invert the DC to AC ?
Danfoss has been mentioned. I’ve talked to a few dealers of 3 phase gear but most aren’t switched on to EV’s yet.
The other items I’m sorting are power assisted steering, air conditioning, and the possibility of a diesel alternator, on Biodiesel, as a back up. Should have room in the engine bay with the traction motor going where the gear box used to be.
If any one has some pearls of wisdom it would be most appreciated. Image
[Edited to replace non-utf8 punctuation marks and tidy up smileys]
Thalass
Real Name: Ben Rypstra
EV first timer
Post by Thalass »
Do as much research as you can! heh.
My configuration is going to be similar to yours, it would seem, with a different donor vehicle. Where are you planning on getting your batteries?
Riverend
EV first timer
Post by Riverend »
Lots of research seems to be the go! Thanks
Batteries - at this point I know only of Thundersky's from EV Power. We're from SA and little seems to be available here. Next stop AC motor/ variable drive dealers in Adelaide to find out more on the controller side. A check of Registration requirements for the conversion is up there too!
Still researching a smallish biodiesel alternator as back up and may be easily removable when not needed. Have seen the pusher/generator trailer idea however I want to keep it simple so my wife will drive it! So extra grunt at times for Air Cond may be needed.
Regenerative braking is on the list and may use, if OK with rego, the cluth pedal to switch regenerative braking as it seems a natural modification to driving style leaving the right foot to cover the existing accelerator brake combo.
The small SUV's seem to have enough room in the transmission tunnel for an 11kw aluminium 3 phase motor. Have found a CMG SLA 4 pole motor weighing 90kgs, 98 NM torque @1460rpm. Image
zeva
Real Name: Ian Hooper
EV first timer
Post by zeva »
Hi Riverend,
Your plans sound pretty similar what Tuarn Brown (our current AEVA president) did with his Suzuki Sierra, i.e using an industrial 3-phase AC motor with a Danfoss VFD. Check out the EV album listing here: http://www.austinev.org/evalbum/1149
Definitely worth dropping him an email to chat about it.
Regarding batteries, unless you need massive amounts of power (e.g for racing), ThunderSky LFPs do seem to be the best option right now. Rod Dilkes at evpower.com.au is the only reseller in Australia I'm aware of - I got my batteries from him and everything went very smoothly.
Ian Hooper
http://www.zeva.com.au
EV first timer
Hi Riverend
Your CMG Motor sounds perfect. That's the way I have decided to go after much fluffing around with looking at DC motors and controllers and getting thoroughly disheartened. You wouldn't have the odd 11kW 4 pole aluminium frame SLA kicking around would you. I am trying to get new prices at the moment.
John
Benonymous
Real Name: Ben Roberts
EV first timer
Post by Benonymous »
The Honda CRV would be a good candidate. They have a really big rear differential set up. It's not just the diff, there's something else hanging off it in the front. Anyway, that would be a good place to put the motor.
Good luck on your project. AC and LiFePO4 is the way to go if you want to do a thorough job.
