Stolen EVSE
Gabz
Real Name: Gabriel Noronha
Stolen EVSE
Post by Gabz »
If anyone sees any keba kecontact EVSE on ebay gum tree etc. contact me
I had one stolen from my front door (it was waiting on a courier) on Monday 13/04/2015. found the shipping labels down the street up one of those pedestrian pathways.
model:
KC-P20-ES240030-00R EN Type2 Socket
22kW+ETH+PLC+RFID
Serial No: 16240755
thanks,
Gabriel
Stolen EVSE
The trouble is the b#$%^&ds won't even know what it is!
Stolen EVSE
Thats why I have HD CCTV at my front door.....:-)
alexeiw123
Real Name: Lex
Stolen EVSE
Post by alexeiw123 »
That's terrible Gabz. Good luck.
Stolen EVSE
Wow 22kw
2020 Model 3 SR+ - k kms 10
Stolen EVSE
reecho wrote: Thats why I have HD CCTV at my front door.....:-)
Ha ha my neighbors are the local criminals so I found it easier to point it at them Image
I recently upgraded my old analog system to the 1080p poe IP cameras.
I wouldn't recommend anything less now Image
Ah not true...
If you have $5k you can get one of those dual thermographic HD IP POE cameras.
..Sorry for your loss.
Did you check any further than the path?
The may have ditched it all at the park further down the road.
Gabz
Stolen EVSE
Post by Gabz »
yeah I walked all the way down to the skate park found nothing.
I thought about cameras start going overboard looking at mobotix. but they aren't cheap any suggests for under $1k ?
TooQik
Real Name: Chris
Stolen EVSE
Post by TooQik »
I don't currently have a system and I have a personal preference for wired over wireless, so if I was in the market I would be considering this system:
FLIR MPX Series
MDK
Real Name: Matt
Stolen EVSE
Post by MDK »
Sorry to hear about this, bunch of pricks
Gabz wrote: I thought about cameras start going overboard looking at mobotix. but they aren't cheap any suggests for under $1k ?
Mobotix are amazing but pricy
I use Hikvision which are pretty good, and can be had for around $125 per camera from aliexpress
reecho appears to be using them too, that screenshot looks familiar Image
Stolen EVSE
I got my stuff from fleabay
ELP brand cameras <$100
Super mini NVR <$60
Can use HDD or cloud blah blah...
Could get away with 2.5" USB + USB hub if backing up with thumb drive.
Best is WD Purple 4TB or seagate surveillance eqv on esata
~$300 gets a 1 camera setup with possible upgrade to 8.
Mine's on a UPS as the power lines like being hit by lightning and power drops out for 1-2hrs here and there.
Stolen EVSE
Gabz wrote: yeah I walked all the way down to the skate park found nothing.
security camera 2000
the RC world uses a lot of there cams as do i (i have 8 different ones) they can also supply different lenses for different needs
Stolen EVSE
Gabz, my cams are Hikvision (thats a sample image above) and come recommended....
This kit will get you rolling.
Hikvision 4 x 2332/NVR Combo EBAY
TooQik
Real Name: Chris
Stolen EVSE
Post by TooQik »
Forgot to include in my first post - NESS are another brand you can look at. I've installed a number of these over the years and had good results with them.
If you're concerned with image quality, spend the largest part of the purchase cost on good quality cameras with adequate resolution. IP cameras can suffer with image quality as the image is compressed at the camera, so check sample footage of the different solutions to see if you're happy with the picture.
