repair of broken auxillary drive motor shaft
Bryce
Real Name: Bryce Gaton
Post by Bryce »
Broken auxiliary drive motor shaft.
Symptom: sudden heavy steering and car even quieter than usual!
Diagnosis: missing shaft, pulley and belts. (Fell out on road. Was able to find all after a bit of searching though :).
Suggested remedy:
Replace armature
Upgrade shaft diameter to 20mm (from 16mm)
Job description:
Unplug aux drive motor power and encoder leads from mini controller;
Unbolt aux drive motor (4 bolts);
Drop off motor for rebuild;
Get either old pulley re-machined to new pulley diameter or get new one made (I did the latter).
Reinstallation notes:
Pay careful attention to:
-     Motor is running in correct direction (clockwise looking at the pulley) – check this before connecting belt. If running wrong way – see addendum/note below;
-     lining up pulley with steering pump and A/C;
-     proper tensioning of steering belt (can be a bit tricky as there is no tensioning arrangement for steering pump, unlike A/C, except to move the drive motor).
Parts suppliers:
Aux drive motor manufacturer: EMP, Bayswater (they can also modify the old pulley if it does not get lost when falling off!);
Engineering works for machining of new pulley if desired/required (mine had some wear and gravel rash, so replaced it).
Addendum/note:
In my case, the aux motor was running backwards after it came back. With a Seba 600 drive, this is easily rectified by using the ‘hidden’ keypad inside the controller – but careful attention must be paid to opening and resealing the controller box. Contact me for details. Earlier controllers require the swapping of a ‘jumper’ contact. Either way, Seba, (in Dandenong, Melbourne), are very helpful.
Bryce
Post by Bryce »
Oops forgot to include the most important step:- perform the usual EV work precaution of isolating the traction pack before beginning!
Bryce
BigMouse
Real Name: Vincent Tannahill
Post by BigMouse »
The the motor is running in the wrong direction, and it's a three phase motor, it's likely just an issue of swapping two of the motor leads. Unless the motor was re-wound as part of the rebuild, nothing could have been done to reverse the direction of rotation.
Bryce
Post by Bryce »
Hi Bigmouse - it's a brushless DC motor that's encoder controlled - you need to swap both 2 power leads AND the right two encoder leads. If they are in conflict, the motor will just quiver and turn itself off. (Had that on the main drive motor of an AC conversion: 5 high speed reverse gears and a bloody slow single forward one, and just quivered and stopped when swapping any 2 power leads. Bloody confusing till we found out the right encoder wires had to be reversed too). I was having difficulty finding the right two encoder wires, so rang Seba to discover it was much easier to push a button instead!
And yes, how rewinding an induction armature can make it go the wrong way afterwards baffles me too - but it did. Thought it best to warn of any potential pitfalls and include their fixes. Hopefully nobody else has that particular hassle. :)
Bryce
BigMouse
Post by BigMouse »
Yeah, you're correct about the encoder leads.
I'm curious why the motor was re-wound while replacing the armature.
Bryce
Post by Bryce »
Sorry Bigmouse - bit loose in my language - a rebuilt rotor, not a rewound rotor (or stator). Its a brushless DC motor. All new rotor to be perfectly correct: with larger diameter shaft and components. Stator untouched. If you can explain how that can make it go backwards after the rebuild, I'll go 'he'! But it did.
Simple fix with the Seba 600 controller as it turns out - IF you know an unmarked keypad is hidden inside the cover. Which is why I put the additional note in the 'fix' post.
Bryce
arklan
Real Name: matt
Post by arklan »
Bryce wrote:Had that on the main drive motor of an AC conversion: 5 high speed reverse gears and a bloody slow single forward one
this is gold :)
Bryce
Post by Bryce »
And we have the video to prove it! Confused the hell out of us at the time. :)
Bryce
