Most LED lighting is not any better than a Fluro at 60Lm/W.
You have to go out of your way to find the 100+Lm/W ones and they aren't cheap.
The only reason I have LED lighting is because I don't want to wait for 5minutes in moon light while the fluro "warms" up.
There is no point making the direction of a house law in Australia.
It's useful for cold climates that need every bit of sun but when it's 45DegC outside I'd rather not have any windows facing North.
not to mention it's not practical in high density urban areas.
Best to work smart with what you have.
Even if my house wasn't a sieve I still have single glazed windows sinking heat - they feel about 15Deg on a cold night and a concrete slab/tiles which feels about the same.
So I'd have to have heaters to fight just the windows and slab.
Summer is about the same except the slab is still cool but the windows are much hotter.
Most Builders now have "eco/green" houses which are the same as any other sieve box but has PV solar panels
They all need a good kick up the...
