Readykilowatt Holden Ute
Readykilowatt
Real Name: Peter Sewell
Post by Readykilowatt » Fri, 18 Jan 2013, 13:55
Finally got to posting some pics of my 2002 Holden ute.
The battery is 100 x 100 Ah Thunhersky.
Greenstage KiwiAC with Semikron SKAI inverter.
160 frame motor with new water cooled housing, and single stage gearbox with park brake.
The cells almost exactly fill the space where the tank cover was.
Motor/Gearbox before it was installed
Stator shrunk into the housing
The Holden is nearly ready to get certified , a few little tweeks of the motor controller.
Pete
Post by coulomb » Fri, 18 Jan 2013, 14:03
Readykilowatt wrote: Finally got to posting some pics of my 2002 Holden ute.
Nice.
160 frame motor ...
It doesn't seem like an off-the-shelf industrial motor, rewound or not. Any details on the motor?
Great to see the KiwiAC controller being used.
[ Edit: brokken brackkits ]
Readykilowatt
Post by Readykilowatt » Fri, 18 Jan 2013, 15:18
The only of the shelf parts are the stator and the rotor.
I had the stator rewound to 80 Vac at 50 Hz
Made patterns for the casing of the motor and gearbox and had them cast in ali.
Used the Holden rear coupling and the second gear epicyclic and made a park brake.
Very happy with the performance.
Pete
Post by Adverse Effects » Fri, 18 Jan 2013, 19:15
that motor / gearbox unit is sweet
nicely done
Post by acmotor » Fri, 18 Jan 2013, 20:15
Now that is an EV conversion !
Can't wait for full specs and performance details.
pete..... more pics please Image
CometBoy
Real Name: Bruce
Post by CometBoy » Fri, 18 Jan 2013, 22:04
Pete that is the most impressive EV motor conversion I have seen in many years!
I also look forward to more information....
Do you have a blog or website on the project?
Nice choice of controller as well.
Good luck in getting it certified. But looking at your workmanship I can’t see you having many issues.
You have inspired me to think of another conversion!
Bruce
I did see this clip last year of the Ute:
http://www.youtube.com/watch?feature=pl ... i7llXr9rGc
BigMouse
Real Name: Vincent Tannahill
Post by BigMouse » Fri, 18 Jan 2013, 22:59
Awesome stuff, I love it!
Readykilowatt wrote: The only of the shelf parts are the stator and the rotor.
Pete
Did you buy an off the shelf motor and pull the stator out, or did you buy just the stator somewhere? The transmission tail shaft is the stock one from the ute?
This seems perfect. If you offered these motor/gearbox assemblies, people would buy them, no doubt. A FWD version would see even more demand.
Readykilowatt
Post by Readykilowatt » Sat, 19 Jan 2013, 02:17
Bought an industrial motor but only used the rotor and the stator lamination's, and yes the tail shaft is stock Holden.
The only other Holden part is the epicyclic gear that is shrunk into a casting as below ....
The park brake gear
The rest of the park brake, the only reason for the linkage to the gearbox is to engage the park brake and provide and indent mechanism.
Pete
36000 Km in a solar powered Celica
http://www.evalbum.com/4093
Post by acmotor » Sat, 19 Jan 2013, 04:50
More please !!!! Image
Stiive
Post by Stiive » Sat, 19 Jan 2013, 17:24
Nice work.
I knew i'd seen this car before, here's a video:
http://www.youtube.com/watch?v=ei7llXr9rGc
"Switch EV's induction motor and gearbox in their Holden Ute conversion, powered by a Semikron SKAI inverter with an Open Source KiwiAC Tumanako control board from Greenstage. Vehicle control is Tumanako Open Source, motor control is STM IFOC."
Rgds,
Stiive
a4x4kiwi
Real Name: Malcolm Faed
Post by a4x4kiwi » Sat, 19 Jan 2013, 18:33
What gear reduction have you got and what diff ratio are you using.
Very nice job. Go the Kiwis!
Readykilowatt
Post by Readykilowatt » Sat, 19 Jan 2013, 19:11
The diff is 3.1 :1 and the gearbox is 3 :1
Stiive
Post by Stiive » Sat, 19 Jan 2013, 19:16
Here's a video of the motor/gearbox as well.
http://www.youtube.com/watch?v=NE4jnWB-N4g
I seem to remember you were going to sell this motor? Is that still on the cards?
Rgds,
Stiive
Stiive
Post by Stiive » Sat, 19 Jan 2013, 19:17
Stiive wrote: Here's a video of the motor/gearbox as well.
Ah yes, its on the comments of that video
Volume pricing for the motor is still a work in progress (which is the goal). One off pricing is roughly $US 8,700.
Yes, the motor control is FOC.
Rgds,
Stiive
CometBoy
Real Name: Bruce
Post by CometBoy » Sat, 19 Jan 2013, 20:13
Pete completely off the subject but was wondering about the back ground of your username ReadyKiloWatt?
http://www.reddykilowatt.org/about/
Did you simply make it up or was it related to the 1926 trademark Reddy Kilowatt?
If so, was Reddy Kilowatt marketed as a brand in New Zealand??
I remember being a big fan of Reddy growing up in Canada....
Btw another cartoon character Willie Wiredhand setup in competition to Ready Kilowatt and court cases followed! These cartoon characters where set up to sell an energy intensive lifestyle and tried to convince electricity consumers to use as much energy as possible.
Bruce
Readykilowatt
Post by Readykilowatt » Sat, 19 Jan 2013, 23:09
Ha !   Readykilowatt !!!
I lived in Seattle for a few years, there was an old power station building I used to cycle past, long since defunct. The Readykilowatt Power Co.
Always thought it was a cool name.
Pete
Post by coulomb » Sat, 19 Jan 2013, 23:15
For convenience, the two videos mentioned above with [ tube ] and [ / tube ] tags (remove spaces for actual use):
PlanB
Real Name: Kris McLean
Post by PlanB » Sun, 20 Jan 2013, 22:42
Nice job on the '95 Celica too Pete, how does acceleration with the AzureDynamics drive compare to the original?
Readykilowatt
Post by Readykilowatt » Mon, 21 Jan 2013, 01:27
A friend here has the same car with the petrol engine in so good for a comparison.
I would say acceleration is about the same as the 2L petrol a bit less over 110 Kph.
But have not done any actual measurements.
Was lucky with the ratios in the gearbox that second gear that I drive every where in has the peak power at about 85 Kph, but dose not drop much until over 110 kph.
Has very good acceleration in first gear but that is limited to about 80 kph, only use first for carpark ramps.
Very happy with the car overall and am regularly doing 185 km to a friends house on one charge easily.
Pete
PlanB
Post by PlanB » Mon, 21 Jan 2013, 03:03
Interesting. So what are the costs like on the SKAI/Tumanako combo you're using now?
Readykilowatt
Post by Readykilowatt » Mon, 21 Jan 2013, 11:44
The SKAI unit is no longer being made, there is the SKIP but I don't know the cost of that though.
I think it has a different connector and is 24V.
Pete
