Weber and Coulomb's MX-5
Post by weber » Tue, 04 Oct 2011, 05:37
Following on from Coulomb's "BLUE IS POSITIVE": What's wrong with this picture? (2 things)
EVWorks assures me that this is how they all arrive from the manufacturer and that we must ignore the polarity markings so solidly embossed in the motor end casting.
The other problem is a bit hard to spot without more information. Here's the clue: The four yellow zinc bolts seen side-on (3/8" UNF) are all the same length and are all screwed in as far as they will go. The two clear zinc bolts seen head-on (M8) were screwed in first.
That's right. The near lower 3/8" bolt has run into the M8 bolt inside the manifold block, which incidentally is aluminium alloy rather than stainless steel as I first thought.
Post by Johny » Tue, 04 Oct 2011, 15:09
Blue and Brown wires appear to be the colours of choice for the Chinese. When I received my 12 chargers they all had Blue and Brown wires on the outputs. On a nicely made sticker on the charger(s)it said that Blue was positive. When I measured a charger I found that Brown was positive - on ALL of them.
Renard
Real Name: Robert Fox
Post by Renard » Tue, 04 Oct 2011, 15:49
I think the Chinese are determined to meet the US market, where, for AC, black is live, and white is ground. So the red/black scheme for low DC voltage would cause problems, since US customers might tend to assume a black wire was positive. So perhaps they use the (international standard) brown/blue for pos/neg. That's what I do when I lack red wire - though I also use red heatshrink in patches. In the same way, they follow the US market by supplying those dreadful imperial bolt and thread forms. Fortunately, it seems the Japanese stuck to metric for their exports.
By the way, as someone brought up in primary school on problems like " Find the cost of 1000 acre-feet of water at 4 1/2 d a gallon" (no calculators back then) the metric system couldn't come soon enough.
Finally, a note of appreciation for all these posts from SI units. I love the still life with pump and pear.
And am always interested in studying people's bookshelves.
Renard
moemoke
Real Name: Andrew Pugsley
Post by moemoke » Tue, 04 Oct 2011, 20:14
The motor is to big for the Tesla, or your Telsa is to small Image
Post by weber » Tue, 04 Oct 2011, 20:43
Thanks for the kind words Renard, and the added fuel for the fire Johnny. Good one moemoke. Image
Renard wrote: I think the Chinese are determined to meet the US market, where, for AC, black is live, and white is ground.
You mean white is neutral (which is of course normally at ground potential). At least the world agrees that green/yellow (or green or bare) is protective earth or ground. See
http://en.wikipedia.org/wiki/Electrical_wiring
Much as I'd like to blame the Americans for this too, I can't see it. We're talking automotive wiring here. In that context, Americans are used to black being zero volts (chassis potential). US car makers GM and Ford use it, same as most other car makers around the world. In their single-phase ac house wiring both black and red are "hot" (red is switched).
And as you say, the whole world, including America and China, has had to get used to appliance cords where blue is neutral and brown is hot/live/active.
So when presented with an automotive device having blue and brown, instead of the expected black and red, you can either map the colours by their distance in some perceptually-based 3D color space (where red and blue are about as far apart as you can get), or map their functions as neutral = chassis, active = hot. Either way you end up with the same result, given that all cars are now negative chassis.
        neutral
blue <        > chassis - zero volts
        black
        active
brown <        > hot - positive voltage
          red
But what we've found now with both our vacuum pump and the Hall effect throttle box from EVWorks, and what Johny has found marked on his chargers, is exactly the opposite to the above. I've asked EVWorks and they don't know why their Hall effect throttle boxes come wired like that either.
BTW, blue = 0, brown = + is the IEC standard for negative-earthed or centre-earthed DC systems. See
http://www.allaboutcircuits.com/vol_5/c ... Wi.bibitem
Despite all this, there are apparently a few car makers that use brown instead of black for zero volts, and yes, brown and black are perceptually similar. But I only found one that also uses blue for hot, actually blue with a yellow stripe, at least for the constant +12 V wire to their car radios. Toyota! See
http://ccs.exl.info/carwires.html
Now I've spent waaay too much time researching this and I'll soon be getting a phone call from Newton asking why I'm not cutting, welding, grinding or painting.
But here's another amusing tidbit about our power steering pump. Both EVWorks and I have confirmed that the end mounting bolts are metric while the side ones are UNF, a fine american thread (no pun intended, but possibly some irony). Now I've just learned from EVWorks what the hydraulic port threads are. These three sets of threads are all in the same block of aluminium so presumably by the same manufacturer. Can you guess what type of thread the ports are?
Post by Johny » Tue, 04 Oct 2011, 21:49
BSP
Post by T1 Terry » Tue, 04 Oct 2011, 21:49
BSPP or BSPT? These are the most common thread types when it comes to hydraulics from what I remember. the easy way to remember diameter sizes is they are multiples of 1/16" It sounds complicated but once you get the hang of th system it really is easy to work with.
Tritium_James
Real Name: James Kennedy
Post by Tritium_James » Tue, 04 Oct 2011, 21:58
No Johny, that's not different enough from the others - still a parallel thread! :) It's got to be BSPT!
Post by T1 Terry » Tue, 04 Oct 2011, 22:12
Actually, looking closer I'd say the brass fitting for the oil return is BSPT and the others are BSPP. I would be very surprised if it's any of the metric threads, they are usually proprietary to the heavy equipment manufacturing mobs. I think CAT even have one of their own.
Post by weber » Tue, 04 Oct 2011, 23:31
You guessed it! It has already got metric and US threads and contradictory polarity markings, so the other thread just had to be BSP. Specifically 1/4" BSP.
The fact that the female thread is rarely tapered, lends support to your argument James, Image but I'm afraid it is parallel, not tapered.
British Standard Pipe. A system where, like the incompatible USA system, the fractional inch designation is not an actual measurement, even approximately, of any aspect of the thread). 1/4" BSP is 0.518" 19 TPI 55° (13.157 mm x 1.337 mm).
At least that's what EVWorks think it is. Trouble is, when I measure the only thing I can measure with sufficient accuracy, the minor diameter, I get 12.7 mm. 1/4" BSP has a minor diameter of about 11.4 mm, while 1/4" NPS (USA) which is 0.540" 18 TPI 60° (13.716 mm x 1.411 mm), has a minor diameter of about 12.2 mm. And my 1.5 mm pitch gauge seems a near miss.
[Edit: The MX-5 itself has M16 x 1.5 threads on the hydraulics, but that's definitely not what's on the pump since that has a minor diameter of (16-1.5 =) 14.5 mm.]
Anyway, I've got a mobile hose guy coming some time this week to make up the hoses. I'll let you know what he decides it is.
I also wonder if, when they re-designated the motor terminals with plastic tags designed to blow off in a stiff breeze, after they found their pumps ran the wrong way, they adjusted the brush advance to compensate. Or whether indeed it is even possible to adjust the advance.
Those Mocen Hydraulics guys are such comedians!
But for god's sake, will someone please translate Murphy's Law into Chinese.
Tritium_James
Post by Tritium_James » Wed, 05 Oct 2011, 16:50
Weber, the fittings in all our watercooling stuff are 1/4" BSP (also called G1/4), so that might give you something you can try threading into your pump to see if the thread fits.
Squiggles
Real Name: Neil
Post by Squiggles » Wed, 05 Oct 2011, 23:02
Just my tuppence worth but I suspect the thread sizes are based on the nominal bore of the pipe, that is a 1/4" BSP thread would be for a 1/4"NB pipe. The nominal bore itself can lead to a whole new discussion.
Post by weber » Thu, 06 Oct 2011, 17:28
Thanks for the thought James, but it would be a lot of trouble to pull any of them out at the moment.
Yes Squiggles, I have read that the 1/4" was the nominal bore of the pipe once upon a time, but I wasn't about to give any quarter in my campaign against non-metric standards. Image
Post by weber » Thu, 06 Oct 2011, 21:09
There's nothing quite like a nice hot cup of tea and a freshly baked bracket.
Or is it an atomic vector plotter.
Post by weber » Thu, 06 Oct 2011, 23:21
Here it is hooked up to the Bambleweeny 57.
Or is it Heinz 57 varieties?
Post by T1 Terry » Fri, 07 Oct 2011, 23:20
Nice bracket, I'm pleased to see others work with "adjustment slots" (the 2 elongated holes) The tapered section in the fore ground of the first picture is a neat work around but I must say, the second picture does miss not have something topical in the background, possibly the can of beans with the label slightly obsured?
Post by weber » Sat, 08 Oct 2011, 05:39
[quote]Here's to the crazy ones, the misfits, the rebels, the troublemakers, the round pegs in the square holes... the ones who see things differently -- they're not fond of rules... You can quote them, disagree with them, glorify or vilify them, but the only thing you can't do is ignore them because they change things... they push the human race forward, and while some may see them as the crazy ones, we see genius, because the ones who are crazy enough to think that they can change the world, are the ones who do.
Steve Jobs[/quote]
[quote]In most people's vocabularies, design means veneer. It's interior decorating. It's the fabric of the curtains or the sofa. But to me, nothing could be further from the meaning of design. Design is the fundamental soul of a human-made creation that ends up expressing itself in successive outer layers of the product or service.
Steve Jobs[/quote]
[quote]Almost everything--all external expectations, all pride, all fear of embarrassment or failure--these things just fall away in the face of death, leaving only what is truly important. Remembering that you are going to die is the best way I know to avoid the trap of thinking you have something to lose. You are already naked. There is no reason not to follow your heart.
Steve Jobs[/quote]
[Edit: Spelling]
Post by weber » Sun, 09 Oct 2011, 00:42
We had a busy EV day yesterday.
The day started with a visit from the mobile hydraulic hose guy, to connect up the power steering pump. He took the pump out to his truck to find the right adapters. When he came back with them I said, "So what are they, BSP or NPS?". He replied, "I don't know. I'm not very good with threads." ... He had just found what fitted.
He couldn't finish the job because he didn't have any right-angle thingies with him, so he'll come back next week. But he left the adapters, so I took them out and measured them. It's much easier to measure a male thread.
It turns out they are M14 x 1.5 ! Not BSP as EVWorks thought, or NPS as I thought, although either of these would probably screw into the port, given that there are only about 5 turns of the M14 thread (in which you could probably fit 5.3 turns of the slightly smaller diameter 1/4" NPS and 5.6 turns of the smaller-again 1/4" BSP). But they would risk leaking or stripping.
Then Coulomb and I worked on populating the rollbar battery box. This is the most visible battery box in the vehicle, particularly when the soft-top is folded down. So we've put our prototype BMUs on the cells in that box, for the expo.
Mum and dad came down from Maleny again to help out. Mum brought a gourmet lunch and mended carpet, did painting and made tea and coffee.
Dad ran the hose between the vacuum pump, the vacuum switch and the brake booster. We wired it up temporarily with some alligator clips and confirmed that it worked. But it does seem like we may need a reservoir, as after 3 brake pedal operations in quick succession there was very little vacuum assist.
Dad and I also reinstalled the clutch slave cylinder and pipes and hoses, and bled the system and tested it.
Sis brought fish and chips for dinner, then we watched "Harold and Maude", that exquisite black comedy from 1971 with the wonderful Cat Stevens sound track. You may remember the modifications made to an E-type Jag in the movie.
Here are its spectacular final moments. This will definitely have to be one of the optional engine-note "ring tones" for the MX-ϟ.
[Edit: Substituted longer better-quality YouTube]
AMPrentice
Post by AMPrentice » Mon, 10 Oct 2011, 16:20
Very lovely looking engine bay! dont know about the heinz can
prefer something more local :) if theres anything local left!
Post by weber » Mon, 10 Oct 2011, 16:59
AMPrentice wrote: Very lovely looking engine bay! dont know about the heinz can
Thanks AMPrentice. I share your preference for local products. The joke was that this power steering pump has "Heinz 57 varieties" of threads and polarity markings. But hopefully, now that those are sorted, it will work well, and without too much noise. We have a plan to run it off a lower voltage to reduce noise if necessary, using an ATA speed controller.
PlanB
Real Name: Kris McLean
Post by PlanB » Mon, 10 Oct 2011, 23:30
Good taste in movies & SF novels but this thread thread has got me discombobulated Dave. Just run the nearest tap or die you have in residence over the offending non conformist part, fill in any slack with liberal application of that white teflon tape so beloved of plumbers & it's all good ain't it?
PlanB
Post by PlanB » Mon, 10 Oct 2011, 23:33
PS: That vehicle is starting to look really swish squire I think I want to lick it.
“We made the buttons on the screen look so good you’ll want to lick them.” S. Jobs.
Post by coulomb » Tue, 11 Oct 2011, 03:33
PlanB wrote: ... fill in any slack with liberal application of that white teflon tape so beloved of plumbers & it's all good ain't it?
I don't think that plumber's tape will work so well at 1500 PSI. That's about 100 atmospheres. You pump your car tyres up to about 2 atmospheres (one above atmospheric).
That's one reason that Weber is paying a professional to make the hydraulic hoses.
PlanB
Post by PlanB » Tue, 11 Oct 2011, 15:49
Fifteen hundred psi hydraulics in an EV! I'm not sure I approve. Couldn't you guys go electric on the power steering?
Post by weber » Wed, 12 Oct 2011, 22:51
Hi Mr B. My mum is pleased that you lick^H^Hke her paint job. But I have no idea what Coulomb is talking about. We don't have PSIs here, and I certainly wouldn't let one near the MX-5. I think he meant to say 10 MPa.
The hose wizard came yesterday morning. I might have said the "hose fairy" but in fact he calls his business Wizard Automotive Hoses, and he looks a lot more like a wizard than a fairy. Fairies tend not to have beards.
Anyway, it's all connected up very nicely. It would want to be, since it cost me $240. The pump itself was $450 + freight.
So I wired it up temporarily to see what the noise was like.
Mate! It's a shocker.
[Edit: Most of this turned out to be due to a resonance that occurs only at a very specific pump speed.
See viewtopic.php?t=980&p=34606#p34606]
There's the 100 Hz-or-so farty noise, presumably the coginess of the 6 pole PM motor. That's not too bad. But at the same time there's this loud 5 kHz-or-so ringing noise that is beyond belief! This is presumably the tooth frequency (not the tooth fairy) of the gear pump, although it does remind one of a dentists drill.
The ringing noise can be reduced by grasping the pump motor body, but not the pump manifold block, I guess the manifold block is already deadened by being bolted to the bracket which is bolted to the traction motor, but I guess the gear pump torque harmonics are transmitted through the motor shaft and magnetically from the rotor to the magnets and hence to the motor casing they are glued inside.
I guess I'll just have to make the best of it now, but there's no way I'd use this brand of pump ever again. There has to be a better way. And maybe something smaller and less power hungry.
The motor casing has some tapped holes in it that might be used to add an extra mounting of some kind to stop the motor casing ringing.
Hopefully reducing the voltage will reduce the noise without reducing the effectiveness too much. I haven't had a chance to try that yet.
But you can forget about any kind of stealth EV driving with this puppy installed.
[Edit: Clarified pump motor versus traction motor]
