Electricity using low grade heat
Re: Electricity using low grade heat
Please explain how this differs from other perpetual motion machines. You can't get more power from a generator than it takes to generate the wind. It's basic conservation of energy.
The topic mentions low grade heat. Where does this come into your proposed machine?
Just a few more points; I realise you're going to push back against criticism. So I'll try to make it simple.
You mention generating 8 m/s of wind with 500 W, and how 8 m/s can generate some 3 kW. But the wind generated from the 500 W blower won't have the power behind it to generate anything like 500 W of electricity, let along 3 kW. The air will simply slow down when it encounters the resistance of the blades of the turbine that connects to the generator. The air at 8 m/s that generates 3 kW of electricity has a lot more power behind it than 500 W. In fact, it has to be considerably more than 3 kW.
This means that your idea violates the law of conservation of energy, and that means you won't get anyone sensible to fund your prototype.
Post by Adverse Effects »
no i don't believe your a prince
no i don't believe you have 35 Million dollars
no you can not have $1000 of my money to help you get your millions out of your country
yes i believe that you are deluded and most likely a scammer
whimpurinter
Post by whimpurinter »
Anyway, Where's the setting to take care of covid19, or the upgrade to take care of covid20 (the one without advertisements, I hate those advertisements).
Well I certainly wouldn't call you a scammer. But I do think your understanding of thermodynamics needs help.
There's always time to learn, and places like this should be about learning, no matter how rudimentary your understanding might be.
OzSpider
Real Name: Derek
Post by OzSpider »
Hello @RevI I have several of those machines, all tested and proven. Please fwd Bitcoin or iTunes vouchers to my personal account and they will be promptly delivered to you.
