MPP SOLAR PIP-7248MAX
dRdoS7
Post by dRdoS7 »
I was recently looking at duplicating my existing 5048MG, and found an Australian MPP Solar store. There was a new inverter: PIP-7248. Sounds like a better idea than 2 MGs for my purposes. Most I have needed recently, since putting the whole house on the MG, is 6000W (which caused the MG to trip to bypass mode). Only an extra $500. Less wiring, etc.
Be able to remove both the MG, & the Classic 200.
dRdoS7
birdibird
Re: MPP SOLAR PIP-7248MAX
Post by birdibird »
I ordered one myself. It will arrive in a few days.
My previous one was also a 5048MG.
I am curious how this new one will be.
I found on this Spanish forum someone who took it apart and reviewed it:
here
I understand it can be quite noisy....
catalincre
Real Name: Catalin Cretu
Post by catalincre »
It is noisy, has 3 fans (already changed to blow up, down blowing direction temperature raised over 50 degree celsius, up blowing it not goes over 42). It suffer from same pv freezing bug. I have already the latest firmware.
dRdoS7
Post by dRdoS7 »
catalincre wrote: Thu, 08 Oct 2020, 01:45 It is noisy, has 3 fans (already changed to blow up, down blowing direction temperature raised over 50 degree celsius, up blowing it not goes over 42). It suffer from same pv freezing bug. I have already the latest firmware.
The noise won't be a problem for me, as it's in the garage, away from the house.
By "freezing bug", do you mean Error #08?
I haven't had one of those with the MG since I turned on grid charging.
I'd hoped they would have fixed that problem in the newer inverters.
dRdoS7
dRdoS7 wrote: Fri, 09 Oct 2020, 17:52 By "freezing bug", do you mean Error #08?
No, this is where the PV power goes to zero until the next day or the SCC is reset. There are also the "dips" where the power goes to zero for a short time (minutes), but then recovers as if nothing had happened.
dRdoS7
Post by dRdoS7 »
coulomb wrote: Fri, 09 Oct 2020, 19:03 No, this is where the PV power goes to zero until the next day or the SCC is reset. There are also the "dips" where the power goes to zero for a short time (minutes), but then recovers as if nothing had happened.
OK. Haven't read of that bug.
Don't think I'd want that inverter. Do the "dips" occur when off grid?
A second MG sounds like the better option!
dRdoS7
catalincre
The dips are on PV side, in case of an off-grid installation will it draw al the current what it needs at that moment from the battery.
But some others inverter type from same family due the same. I hope @coulomb will patch the firmware and get rid of this bug.
birdibird
Post by birdibird »
Maybe file a complaint /request to MPP Solar / Voltronic. If we all do that, they might release a firmware upgrade....
dRdoS7
Post by dRdoS7 »
birdibird wrote: Sun, 11 Oct 2020, 03:34 Maybe file a complaint /request to MPP Solar / Voltronic. If we all do that, they might release a firmware upgrade....
I've conversed with MPP Solar about the #08 Error of the MG, and haven't seen any action from them.
The faults with the MAX seem even worse.
dRdoS7
birdibird
Post by birdibird »
Hmm, interesting, as there were updates addressing the #08 error. But as I understand you were not notified about that?
Well, I already ordered the Max and it will arrive Wednesday.
We can compare the firmware versions.
We'll see....
dRdoS7
Post by dRdoS7 »
birdibird wrote: Mon, 12 Oct 2020, 03:04 Hmm, interesting, as there were updates addressing the #08 error. But as I understand you were not notified about that?
I did see an update, but thought that the error still occurred, in some cases. There was a work-around too. Both on the SA Powerforum.
No update notification from MPP.
Also saw this:
Factory firmware version 71.71 for PIP-5048MG / Axpert MKS II 5K-48. This is supposed to fix the PV dips and freezes problem, though we're not aware of any users that
On the first page of the MG thread. So it does have that same problem! I haven't seen it on my MG (71.20).
We'll see....
Nice.
dRdoS7
birdibird
Post by birdibird »
Updating this thread.
I was on firmware 45.01 and had all kind of weird bugs, but since I flashed 45.04 and display 12.03 the Max is behaving a lot better.
I didn't try the 90.xx series yet. Any of you did?
Antonio Battaglia of solarpower24.it offered to do a distance update through teamviewer.
He cannot just give me the file as Voltronic made it for him to support his batteries. Fair enough.
Curious which version that one will be.
sergea
Post by sergea »
Hello,
Do you mean they got Voltronic to patch to firmeware to get their LiFe4po batteries BMS handle by the inverter ?
birdibird
Post by birdibird »
sergea wrote: Tue, 15 Dec 2020, 23:10 Hello,
Yes, that's correct.
birdibird wrote: Tue, 01 Dec 2020, 02:43 I was on firmware 45.01 and had all kind of weird bugs, but since I flashed 45.04 and display 12.03 the Max is behaving a lot better.
Not me, but a user on the Powerforum has, with some success. See this post and several after it.
I suspect that the 45.XX firmware has been replaced by 90.XX, except for the PIP MAX 120 V models, which will have the same version as the 230 V models, except starting with 90.XX instead of 45.XX. For example, the 90.19 firmware, when running on 120 V PIP MAX hardware, will report as 45.19, and of course behave as a 6500 W 120 V model. (That's over 54 A AC output, ouch!)
Edit: However, they don't seem to have settled on the numbering scheme until recently. For example, 90.11 reports as 50.00 on 120 V MAX hardware.
sergea
Post by sergea »
birdibird wrote: Wed, 16 Dec 2020, 07:55
Curious, they just answer to me no bms support for their batteries on their voltronic inveter. :roll:
BTW I will be interested in getting the capture of the messages that the inverter is exchanging with the pylonthec, in order to determine which parts of the pylonthec rs485 battery communication protocol specification are really used.
birdibird
Post by birdibird »
sergea wrote: Thu, 17 Dec 2020, 02:28
He told me the wall version of this battery has bms communication support with voltronic inverters, the rack version does not due to a different bms used.
birdibird
Post by birdibird »
coulomb wrote: Wed, 16 Dec 2020, 08:57
Yes, my supplier confirmed the 90 series are the latest ones.
I had no problem with 45.04, (except for a small bug that the load W was not always displayed with small loads) but I am off-grid.
I flashed 90.11 yesterday and my batteries were much lower this morning than with 45.04. Not sure if that is coincidence or not.
I will now flash 90.19 as I didn't see that update until now.
(230V 7200 MAX)
