AGM for home storage?
memecode
Real Name: Matthew Allen
Post by memecode »
So I've been looking around for home storage solutions for a while now. For instance the powerwall 2 would be a nice amount of battery but I balked at the 12k cost. I doubt I'd ever see a return on that. For reference I have a 3.35kw solar array that most of the time feeds back into the grid at 12c/kWh. We might see 20kWh of generation on a sunny day in summer and maybe 10kWh in winter. If there was a solution for well under $10k where I could store around 10kWh I'd be pretty keen.
Today I was just googling around and bumped into this AGM battery bank. And it's a lot under the price of a powerwall. But obviously it doesn't come with any BMS or inverter. And yes I'm aware that I'd need to keep the discharge to 50% for any real cycle life. A lot of the year our house uses just 10kWh on average.
I'd like to know what sort of round trip efficiency these AGM's could have? Is there a reason that a lot of home storage is lithium based chem?
What would I need to turn it into a functional system, ie BMS and solar/mains/house/battery connectivity? Obviously I already have an inverter, but I doubt it's ready to plumb in a battery as well.
Maybe there are companies that can just do that all for me? (Im in Sydney). I don't mind a bit of DIY but there are limits.
Re: AGM for home storage?
Lead batteries have been the mainstay for off-grid and stationary energy for a long long time - as long as the solar charge controller is set up to charge lead properly they are a solid choice.
Not exactly cheaper though - particularly since you aren't able to access a fair bit of the energy stored as the sag is pretty bad.
I received an "invitation" to attend a Powerwall 2 sales pitch event and was interested to see the comparison between $/Wh between the Powerwall 2 and inverter v our lithium system using Winston cells and inverters. the set up came out to 72.4c per Wh for the Powerwall 2 and 26.5c per Wh for our set up with a 5kW inverter that also included an 80 amp MPPT solar controller and a 60 amp mains charger.
As far as lead acid v lithium for off grid power or back up power, $ per useable Wh and expected cycle life, lead acid is not even close to competing. A system we installed about 3 yrs ago at the local marina had all the neh sayers telling him they'd catch fire, they hadn't proved themselves, they were far too expensive etc. The same people are now paying for their second set of batteries because they pushed them too far in an attempt to prove they could do the same with their lead acid batteries as he could do with his lithium batteries. Now they reckon he must be cheating and has a hidden power cord plugged into the mains supply that he isn't telling them about :roll:
If anyone tells you they are getting more than 3 yrs out of their lead acid batteries it is because they aren't using the available 50% capacity they have installed. If they only use 25% the battery needs to be 75% stuffed before they realise they have a problem.
paulvk
Post by paulvk »
Lead acid the rule is use 20% to get long life
Lead acid sealed no more than 1/10 of Ah as current so 100Ah 10 amps max , 500Ah 50 amps max
Flooded lead acid can cope with greater discharge currents because you can add water
Giant power batteries "STAY AWAY" too many having problems!
Best lead battery for the money is the T105 series flooded (about $4500 with central watering 450Ah two banks 16 batteries) as so many are manufactured used in golf carts and lots of industrial machines.
When I finally get my Nickel Iron ones installed I will let every body know how they perform
Post by 4Springs »
memecode wrote: Tue, 22 Oct 2019, 09:06 Today I was just googling around and bumped into this AGM battery bank. And it's a lot under the price of a powerwall. But obviously it doesn't come with any BMS or inverter. And yes I'm aware that I'd need to keep the discharge to 50% for any real cycle life. A lot of the year our house uses just 10kWh on average.
For $5000 you'd get roughly 15kWh of Francisco's NCM lithium cells: viewtopic.php?f=17&t=5909&start=25
Not that I'm suggesting they would be the best chemistry for a home storage battery, just pointing out how cheap lithium is getting.
Lead acid is much simpler to use, electricians know how to hook them up, and you don't need a BMS.
doggy
Real Name: David Kerr
Post by doggy »
AGMs can be very long lived and reliable:
a. I had a 1000AH/12V set up on my barge in France. After 8yrs, they are in almost perfect condition. Average cycle depth only 23%. 4.5kW inverter. Excellent solar MPPT plus engine 4step temperature controlled charging plus 120A mains charging (when mains available) plus motor generator putting out 200A and rarely needed. Victron batteries so top quality. They will certainly last several more years. Charge efficiency 98% (Measured over their lifetime). Full round trip efficiency a couple of percent less. 660W solar. Full time 230V.
b. I have 520AH of AGMs (12V) on my yacht. 200W of panels. temperature controlled charging (always). Solar and wind MPPT 4 stage charging. Now 11 years and still in excellent shape. Charge efficiency 97%. Fusion batteries.
c. My daughter has offgrid 48V x 1200AH German AGM batteries. Cycled every day (on a farm) about 20% average DOD....max 60% is very rare. Specs are awesome for cycles at those DODs. They are now 9 years old and going strong. 6.6kW solar with SMA equipment.
At home I have two Lithium banks. 2YV x 460AH and 25V x 180AH.
So, nothing at all wrong with AGMs as long as you do not cycle them too deep. Manufacturer curves are worth consulting and following carefully. Bigger is better as lower cycle depth, lower internal impedance and due to Peukert effect you can pull out decent AHs even at reasonably shallow discharge.
Of course cost does need to be considered but do NOT believe AGMs have a short life. It is only short if they are abused or cheap and nasty construction.
Personally, I'm increasingly happy to use Lithiums due to DOD, cost, size, weight etc.
Dave
Recently finished an AGM battery replacement with Winston LYP cells. The original AGM battery was built from 2v 600Ah cells to build a 48v battery. We replaced it with a 300Ah lithium battery, removed the 5kva on a good day heavy as lead inverter and replaced it with 2 x PIP 5048 inverter/chargers in parallel. The system was installed 20 yrs ago, so that makes it sound like they had a great cycle life out of the AGM batteries, but in reality the system ran more as a solar powered set up during the day and a 6.5kva genset powered it at any other time power was needed. To run the coffee machine had always required the generator, same for the swampy air conditioner and if the iron was required .... just about anything apart from a few lights and the TV and in winter it even required the generator run for a few hrs in the morning and evening. Listening to the use pattern, the battery pack had really passed on after 7 yrs or so as far as a serious energy storage unit.
The solar is also 20 yrs old, Sharp 175w panels, a PWM controller, 24 panels connected as 2S12P to give a Vmp of 70vdc @ 25*C. That should have been plenty to get the batteries up to the required 58.4vdc for the bulk and absorption stages, but the wiring used to run the 70vdc back to the junction box was barely 2mmsq so the 5 amps would have been struggling to make it from the panels to the junction box on each array.
We rewired 2 of the 6 panel arrays to 3S4P and fed that into the MPPT controller in one of the inverters, the other 2S6P into the other MPPT controller in the other inverter. Still need to be there on a sunny day to see if the rewire helped.
The system has now run for 2 weeks and only required a 3/4hr run of the generator after the day of no solar connected and the SOC dropped to 30% by around 6pm. Apart from that, the coffee machine, iron, air con and all the other bits are being powered from the solar and the 300Ah of lithium batteries, even though it has rained/been heavy overcast there every day since we put the batteries in. The system never had that capability, even when new with the 600Ah AGM cells.
