Small wind turbines
Posted: Mon, 17 Jun 2019, 19:27
I am looking to erect a few wind turbines to supplement my off-grid solar system as we are getting somewhat enough wind here in Southland, New Zealand and very little sun in winter (there is enough sun when the sky is clear but it is often blocked by very dark overcast). This should save lots of money otherwise spent on petrol for the generator.
A quick search for what's in store has left me puzzled. On Aliexpress you can find lots of turbines which physically appear the same (rotor diameter 1.3m, weight 9kg) but with significantly different rated power: from 400W (perhaps the most realistic) to 1500W and even more. A local NZ store sells 3.5kW turbine with rotor diameter 3m (and much much higher price tag).
Am I right assuming that if one turbine with 1.3m rotor diameter is rated 400W, then another one with the same weight and diameter physically cannot produce 1.5kW? Does anyone here have experience with wind turbines like that?
