Page 96 of 103
Re: PIP-4048MS inverter
Posted: Thu, 27 Sep 2018, 21:09
by Vissie
Thank you. I will try it
Re: PIP-5048MS inverter
Posted: Sat, 06 Oct 2018, 04:33
by 6mdx
Hi all, what setting controls the 04 low battery warning. My 5048ms is triggering at 49.5 v , which is not low for my 15s lfp batteries.
TIA Robert
Posted: Sat, 06 Oct 2018, 07:02
TIA Robert
Hi Robert. The low battery warning thresholds depend on the Low Cutoff Voltage (setting 29). In the standard firmware, a low battery warning is given after the battery voltage falls below cutoff+2 V and stops after the battery voltage goes above cutoff+4 V. When we modify the firmware for LFP batteries, we change these to cutoff+0.5 V and cutoff+1 V.
I am pleased to announce that Coulomb and I are making good progress in porting our patches to the PIP-5048MS (Axpert MKS 5K pf1 with 64V option) because forum contributor Monkeytom has loaned us two of them for testing. Thanks Tom!
Posted: Sat, 06 Oct 2018, 10:14
by 6mdx
I am pleased to announce that we are making good progress in porting our patches to the PIP-5048MS (Axpert MKS 5K pf1 with 64V option) because forum contributor MonkeyTom has loaned us two of them for testing. Thanks Tom!
Hi Weber, thanks for the info. My two 5048ms turned up the day after Toms. I still havent seen the parallel boards.
Great that you two are making progress. It pretty exciting porting all your previous efforts to the new generation inverters.
Cheers Robert
Posted: Sun, 07 Oct 2018, 01:37
by Savage1ZA
Hi Guys,
Is there any new / additional information available about the error 51? My 5KW Axpert also now out of the blue, started with this very intermittently. What's also very strange to me, is that it only occurs during VERY hot and sunny conditions (30C+ ambient). Irrespective of load, and never during the night. In fact, it's always between round about 11AM and 3PM. Just as quick as the Inverter will start giving this fault condition (on and off, intermittently), just as quick it will just magically stop and return to normal pro-longed operation.
No change to any settings, no change to any loads, no change to batteries. As randomly as it starts, just as randomly it stops. My PV is also very close to the max acceptable parameters (as someone else posted) - I too, will be disconnecting my PV tomorrow to see whether the fault / issue persists without the PV connected. Someone else said they stopped experiencing the problem after disconnecting the PV.
Posted: Sun, 07 Oct 2018, 08:25
Hi Guys,
Welcome to the forum.
You may be providing it here; see below. Error 51, for other readers, is documented in the user manuals as "Over current or surge". It seems to relate specifically to inverter current. There are separate limits for battery and line (bypass) modes; I assume that your problem is only when in battery mode.
This suggests something is drifting with temperature, and the temperature may be elevating because the solar charge controller is working hard.
If there really is no correlation with actual load, then that strongly suggests that the problem is a measurement problem, not an operating condition problem.
The correlation with PV has been mentioned before. I can't see how it makes any difference to the main firmware. So it may well be that the SCC (Solar Charge Controller), which is now packed in rather tightly with the main board components, is causing heating of some measurement components, e.g. the hall effect current sensor for inverter current.
What is your main firmware (U1) version number?
If it's earlier than 73.00, the it may not be working the fans hard enough. In 73.00, they increased the fan speed for a given PV power. Initially, I thought that this was a way of making the inverter cool harder during the day, and be more quiet at night when people appreciate the quiet more. But now it looks like the SCC might need more cooling than it used to, certainly more than back when the SCC heatsink used to be on top of the inverter. So updating to factory or patched firmware based on 73.00 might be a simple solution. It might also be worth noting the inverter temperature when the overload happens.
Instead of a sensor drift error, it might be that the inverter automatically derates its maximum inverter current limit as the temperature increases. I've not seen this in the firmware so far, but I haven't been looking for it, and might just not have come across it as yet.
The other possibility is that some EEPROM settings might be corrupted somehow, causing up to about 25% scale errors, and possibly offset errors as well. There is a command to reset these to factory defaults, but I would not recommend using it except as a last resort. You would lose any factory calibrations by using that command. There are commands to adjust the scale and offset eeprom calibration values; this would be better if you notice that power readings are consistently in error, and suspect that these errors are pushing your inverter to think that it's over the limit. But you say that there is no correlation with load, so this seems unlikely in your case.
[ Edit: Added sentence about losing factory calibrations if using the force all EEPROM to defaults command. ]
Posted: Wed, 10 Oct 2018, 07:13
We have continued this discussion on the Power Forum. To summarise,
  • Error 51 is not restartable, whereas "ordinary overload" (error 7) is restartable.
  • So this is a "never exceed" situation, protecting the circuitry from catastrophic failure.
  • This error seems more common in South Africa, where mains surges seem more prevalent than elsewhere.
  • My latest suspect is the MOV (Metal Oxide Varistor), associated with the output of the inverter.
From http://www.resistorguide.com/varistor/ :
MOVs degrade when exposed to repeated surges. After each surge the MOVs clamping voltage moves a little lower, how much depends on the joule rating of the MOV in relation to the pulse. As the clamping voltage falls lower and lower, a possible failure mode is a partial or complete short circuit, when the clamping voltage falls below the protected line voltage.
It goes on to say that this situation could lead to a fire hazard. Fortunately, the PIP/Axpert firmware is monitoring the peak current, and when it exceeds a threshold (it seems that the threshold starts at 40 A instantaneous, and increases to 80 A instantaneous if all goes well), fault code 51 (error 51) is issued, saving the electronics from catastrophic failure, possibly including fire.
MOVs have a marked negative temperature coefficient. As temperature increases, their threshold voltage decreases, and their leakage current increases. Both these effects would lead to the error 51 coming up more frequently when the inverter is hot, e.g. due to high solar charge current during the hotter part of the day.
Edit: Note please also @JvdSpoel and @ejb, since my guess has changed.
Posted: Wed, 10 Oct 2018, 16:38
Release Version of Patched Firmware 72.20c for some PF1 models with the 64V option
[Edit1: On 12-Oct-2018 we replaced beta 72.20b here, with beta 72.20c that has a new load-control or go-to-standby command.]
[Edit2: On 11-Nov-2018 we replaced beta 72.20c here, with release 72.20c. The only change was the first letter of the version number (from B to L).]
This patched firmware fixes the premature-float bugs in the manufacturer's firmware for the PIP-5048MS, Axpert MKS 5K-48 (PF1 with 64V option) and equivalents. i.e. machines supplied with main firmware version 72.xx where xx ≤ 30. It also contains our Dynamic Current and Load Control (DCLC) and AussieView™ additions, and we have provided a version with our voltage and current threshold changes for LFP cells. i.e. It has the same functionality as 73.00c (PF0.8) except that in the LFP version, the minimum tail current to go from absorb to float has now been reduced from 5 A per machine to 3 A per machine.
Finally, 72.20c also has Dynamic Load Control (DLC). This allows you to send a serial command (MNCHGC0497) to force a machine into standby mode, reducing its power consumption (in our test with 2 parallel machines, from around 60 W to 11 W per machine). This is similar to turning off the bottom switch, except the processor keeps running so it can accept other commands, such as MNCHGC0498 to return it to normal operation. With no PV or AC input, turning off the bottom switch still powers everything down after about 20 seconds, including the processor. The zero in these commands can be replaced with other machine numbers in a parallel system.
Thanks go to forum contributors and friends @6mdx and @Monkeytom for the loan of two PIP-5048MS inverters for testing. Also the anonymous benefactor who sent us the firmware update file. You know who you are. Many thanks to you all.
Here are the zip files with all the software you need, to reflash your PIP-5048MS or Axpert MKS 5K-48 (PF1 with 64 V option), and to revert to factory 72.20 firmware if required.
Note: This firmware is only suitable for the 48 V models with a single low-voltage MPPT and a power factor of 1 (5kW/5kVA) and the 64 V maximum battery voltage option. It is not suitable for the older models with a PF0.8 rating (4 kW/5 kVA), and not PF1 models without the optional 64 V hardware, and not models with a maximum PV array open circuit voltage greater than 145 V DC. Parallel or phased machines must all run the same patched firmware version.
dsp_LF1_72.20c pf1 64V.zip
(1.93 MiB) Downloaded 20 times
For lead acid (24S), lithium cobalt-blends (LCO, NMC, NCM, NCA) (14S) and lithium titanate (LTO) (21S)
dsp_LC1_72.20c pf1 64V.zip
(1.93 MiB) Downloaded 30 times
See these reflashing instructions but ignore the zip files there.
It should go without saying that you use this at your own risk.
Posted: Wed, 10 Oct 2018, 18:28
by Savage1ZA
@coulomb started to open up and test various components inside the inverter today as per the service manual. The entire battery side bus of the main board, is effectively toast and blown :shock: Right up to (and including the) PWM CNTL.
There is absolutely NO visible damage / burns anywhere, but testing the components resulted in the one failure after the next... Right on Axpert for the Error 51, it is indeed an indication of something rather seriously wrong with the Inverter.
Needless to say, I am in the market for a new main board, and failing that, a new Inverter.
Posted: Wed, 10 Oct 2018, 18:58
coulomb, [ I ] started to open up and test various components inside the inverter today as per the service manual. The entire battery side bus of the main board, is effectively toast and blown :shock: Right up to (and including the) PWM CNTL.
? But didn't you say that it recovered and never showed the problem at night? It sounds very suspicious that every component you test is faulty, and yet there is no visible sign of damage.
It sounds like you have been misinterpreting the service manual checks. Many of those are "resistance" checks, which are only valid with one model of multimeter. I use those ones more as a guide than as gospel. The diode measurements are far more useful.
Also, I would not expect the battery side components to be faulty, though it is possible that they failed as well as the inverter components, buck transistors, and battery-side to high-side full bridge.
I still think it's worth replacing the MOVs. I'd replace them all, since I suspect they all will have seen much the same overload events. It may well be that all your semiconductors are fine, saved by the Firmware calling fault code 51.
Posted: Wed, 10 Oct 2018, 20:02
The MOVs seem to be Brightking brand, part number 561KN20. Specifications here; basic specs:
350 VAC, 504-616 V for 1mA, clamp at 920 V and 100 A, 280 J at 2 ms. 20 mm diameter, thermal fuse protected.
The nearest I can find in a quick search is this part from Mouser (comes up for me in AU$; use the Mouser part number 576-TMOV20RP385E in your local Mouser web page). Basic specs:
385 VAC, 558-682 V @ 1mA, clamp at 1025 V and 100 A, 300 J at 2 ms. 20 mm diameter, thermal fuse protected.
[ Edit: this part (Mouser part number 576-TMOV20RP320E) has lower voltages, and may be more suitable:
320 VAC, 459-561 V for 1mA, clamp at 840 V and 100 A, 270 J at 2 ms, 20 mm diameter, thermal fuse protected. ]
Posted: Wed, 10 Oct 2018, 20:21
by Savage1ZA
That's correct yes. It only showed the error during the day, and on warm days. It's not every single component, but it is a fair amount of them... A summary (posted extensively about this on the other forum)...
Main MOSFETs:
Resistance GS: 11.7K (fine). GD 130k (manual states 250k?), DL O/L Considering I get 130k across ALL the MOSFETs and not one, I am going to assume a reading of 130k instead of 250k is sufficient
Diode: SD 0.43V EXCEPT Q14 where I get a O/L This is definitely a faulty MOSFET.
Drivers:
Q46, Q48, Q41, Q43 Resistance BE 26M (manual states 420k), BC 26M (manual states 420k), CE 30K (correct)
Q46, Q48, Q41, Q43 Diode BE 0.6V (all fine), BC 0.6V (2 fine, 2 dead), CE (all busted)
Q15, Q16, Q41, Q43 Resistance BE 26M (manual states 420k), BC (26M (manual states 420k), CE All over (should be 30K)
Q15, Q16, Q41, Q43 Diode BE 0.6V (all fine), BC 0.6V (2 Fine, 2 busted), CE (all busted)
A few resistors also faulty
Q60/Q61 Mosfets blown
I've pretty much given up measuring at this stage... The part (component) numbers in the service manuals, matches the part (component) numbers in the inverter, so I'm fairly sure I have the correct manuals for the inverter...
Posted: Wed, 10 Oct 2018, 21:10
by dinu_tiberiu_george
For 5048MS PF1 not 64v model do you have any patch?
Is there any way to pass beyond the 58.4 v bulk/absorb voltage? I see in the manual the cut-off voltage of 60v. Is there any risk if I charge the battery with an external charger, at let say 59.5 v?
Posted: Thu, 11 Oct 2018, 03:20
by 6mdx
Hello weber and coulomb, thanks for your efforts on the new Beta Version of Patched Firmware 72.20b for PF1 models with the 64V option.
Good fast work. I will try it today.
Did you get the parallel boards from Tom? If not mine have arrived.
Cheers Robert
Posted: Thu, 11 Oct 2018, 06:10
Hi Dinu. We don't know. Any time spent at a higher than usual battery voltage will tend to age the capacitors more rapidly and increase the risk of MOSFET failure. Short periods above 58.4 V but below 60 V should be OK.
I assume this is for equalisation of lead acid cells approximately once a month. If so, it would be best if you could disconnect the PIP-5048MS while the external charger is in use.
It is possible that the 73.00c (pf0.8) firmware might work on a PF1 not-64 V model, but it may limit power to 4 kW. We have not tried this and do not know whether it might have other bad side-effects that will destroy the inverter.
It is possible that the 72.20c (64 V) firmware might work on a PF1 not-64 V model, but it will probably not protect the inverter against excursions to high battery voltages, and you should be very wary of using any setting above 58.4 V, and certainly not above 60 V. We have not tried this and do not know whether it might have other bad side-effects that will destroy the inverter.
I thought that all PIP-5048MS from MPP Solar came with the 64 V option. If so, the label on the side should say "Model: PIP 5048MS(64V)". Also, the 64V models have main firmware versions 72.xx where xx ≤ 30, while the not-64 V models have main firmware versions 74.xx.
Posted: Thu, 11 Oct 2018, 06:30
Cheers Robert
Thanks Robert. We transferred the parallel boards from my 4048s. We would not have posted the firmware as beta without testing parallel operation. As it was, we found a bug when we did so, but we eventually tracked it down and fixed it.
I have belatedly added an acknowledgement of your contribution, to the firmware post above, after I was reminded that it was you who first proposed to loan us a PIP-5048MS so we could test our patches. And it was you who got Monkeytom involved, when his inverters arrived before yours. Thanks for that. And thanks for your upcoming beta testing.
Posted: Thu, 11 Oct 2018, 06:51
by 6mdx
Hey weber , glad it all worked out. I installed the new lfp patch this morning on single inverter. The second inverter is still in its box. All seems to be working, if only I had some sun.
Love Aussieveiw. Thanks
Robert
Posted: Thu, 11 Oct 2018, 08:05
by 6mdx
Now that I have moved from PWM 5048 to MPPT 5048, I have a new dilemma.
My 60 cell panel have open circuit voltage of 37.
2S is the current configuration open circuit is 74 V, but under load this is 55 to 62 volt.
5048 MPPT range is 60 to 115V, with max PV of 145V.
Today with heavey cloud the PV voltage is around 55V. And very little current
Should I suck it up and reconfigure to 3S?
Will it make a worthwhile difference.
Ps my panels are all earthed as per standard.
TIA
Robert.
Posted: Thu, 11 Oct 2018, 13:04
To answer that, I need to know: Are you using 16S or 15S LFP? What make and model are your panels? I already know your approximate location and therefore your temperature regime.
Posted: Thu, 11 Oct 2018, 18:45
by paulvk
I have all my panels as strings of three tested at two's it worked but only with good sun little cloud
went to strings of three my max voltage has been 119v and it works much better with cloud
Posted: Thu, 11 Oct 2018, 21:31
I assume that means that each of your strings is three panels of 60 cells each?
Usually the panels with output around 250 W have 60 cells. Panels around 200 W and those around 300+ W usually contain 72 cells; the 200 W panels use the smaller 125 mm cells. A few panels have had 54 of the larger sized cells, they seem to be rare now. They were ideal for 3S (strings of three panels in series).
Strings of three panels with 72 cells (either size) are more likely to have cold morning voltages that are too high for the PIP/Axpert Solar Charge Controller.
Posted: Fri, 12 Oct 2018, 04:49
by 6mdx
Weber, my batteries are 15S.
The panels are REC 250 watt.
I would have to get out of bed to find the model number...... lol
Posted: Fri, 12 Oct 2018, 12:23
3S of these 60 cell panels would certainly stay within the SCC's open circuit voltage spec of 145 V, and would give the best energy yield. 3S will stay under the legal open circuit voltage limit of 120 V if the operating temperature of your panels never goes below 0 °C (dawn in mid-winter). Given that you're using the lower battery voltage afforded by 15S LFP (say 51.8 V absorb, 50.4 V float), energy yield from 2S would probably not be very much less than from 3S. You would lose out on still hot days. It won't achieve max power in absorb if the PV cells go over 54 °C and it wont maintain float at max power if they go over 60 °C.
Posted: Fri, 12 Oct 2018, 18:12
by Revlac
Some time ago We had a 5048Hs inverter and a 4048HS running well on the same 300ah battery bank, the 5048 was running the normal house load and the other would run the water pumps and the air conditioner occasionally.
On a day when the 4048 was sitting completely idle and the other was running the house at about 400watts, one of the inverters failed and took out the other one at the same time, so I can confirm this happens.
They were on completely different circuits apart from the battery, I suspect a transient surge on the DC lines.
And mostly the same parts blown on each inverter.
Battery side Power Mosfet's 8 of them busted
Bus Side components IGBT's 2 of them gone
R54 R57 burnt open
D69 open
Roasted the 200amp fuse.
A few other parts and some zenor diodes on the DC/DC IGBT bus side where also open circuit and not in the checklist on the repair manual.
I have repaired the 4048HS and it has been working hard in the shed ever since and very pleased with it, It was not difficult to repair, just time consuming checking all drive components are in working order before any attempt to power up.
So it was well worth the effort to repair it and learn about its working along the way. :D
Will repair the other one later.
Now have a 5048MS unit ready to go in case something happens to the other unit.
Oh I should mention the only other thing that has caused the inverter to stop was A Taurus Hot Air Gun on the low setting, cant remember the error number, but the inverter only disconnects the output relay and within 10 seconds it reconnects and running again.
The little geny didn't like the hot air gun either.
I think the later model Main boards have a bunch of TVS Diodes (under Main board) on the battery side Mosfets?
Aaron
Posted: Fri, 12 Oct 2018, 19:10
A new patched firmware feature has been added, called Dynamic Load Control. This allows a serial command to force a machine into standby mode. This is similar to turning off the bottom switch. However, the processor keeps running, so another command can be sent to turn it back on, or do anything else. The fans are still running, but the power in standby mode is around 11 W, compared with around 60 W for a machine with a parallel card and operating in paralleled mode. So that's a nice saving.
When machines are paralleled, one or more or all machines can separately be forced into standby mode, or back to normal operation. Of course if all machines are put in standby, the loads will not be powered, but this might be exactly what is needed if your BMS detects a lithium cell going undervoltage.
With suitable monitoring software, this could be used to keep wasted power low when demand is low, yet have the power of two or more machines available when needed. It's kind of cool pressing buttons on a phone and having an inverter go click and change its display :geek:
This feature has been incorporated into patched firmware version 72.20c for PIP-5048 or Axpert 5K-48 (PF1) models with the 64 V option.
The Dynamic Current and Load Control Manual has the details.
This feature will hopefully eventually find its way into a new version of the patched firmware 73.00c, for PF0.8 5 kVA models.
