Hi, I just had the display & all the controls on the centre display fail (ie display blank & none of the switches around the display worked). Stopped the car for business, & same thing happened on restart. BUT later (when I stopped again), the display did a Morrison (as in Nothing to see here!) & worked normally. Fully Weird!
Anyone else seen that?
Centre Display & BT etc failed to work!
- Real Name: Paul
Re: Centre Display & BT etc failed to work!
I have seen it mentioned on the Ioniq forum, only for the 28 but no concrete cause and dealers couldn't help because it wouldn't manifest when taken in.
Is this after the recent map and software upgrade?doug wrote: ↑Wed, 03 Mar 2021, 13:43 Hi, I just had the display & all the controls on the centre display fail (ie display blank & none of the switches around the display worked). Stopped the car for business, & same thing happened on restart. BUT later (when I stopped again), the display did a Morrison (as in Nothing to see here!) & worked normally. Fully Weird!
Phil
2020 Kona Electric Highlander - White + sunroof
Phil
It was after the last s/w update (no maps No maps in my case.
Ok.
I've had weird things happen that relate directly to the map and infotainment upgrade, but not a failure to operate at all.
Phil
Phil
