Type 2 charge leads
Type 2 charge leads
Post by antiscab » Wed, 11 Jul 2018, 13:11
Hi guys,
The latest generation of EVs are being shipped without home charge cables. For those not in the know, these allowed you to charge the car from any normal power point.
If you're willing to roll your own, I'd recommend getting one of these
http://s.aliexpress.com/jMrMFbAJ?fromSns=Copy to clipboard
Still need to put an Australian plug on it, and around 6 weeks shipping time.
Re: Type 2 charge leads
Post by antiscab » Wed, 11 Jul 2018, 15:51
Oops, I take it back. Turns out China has their own standard which uses connectors that look the same as the type 2 mennekes units.
Post by antiscab » Wed, 11 Jul 2018, 15:53
ZWET IEC 62196 standard Type 2 NEW ELECTRIC CAR CHARGER EVSE LEVEL 1 OEM IEC 62196-2 / 16A Type 2 electric vehicle charger
http://s.aliexpress.com/AJvYvIJR?fromSns=Copy to Clipboard
That's the right one
Post by antiscab » Sat, 17 Nov 2018, 08:18
Here's a 3 phase portable evse I came across for $640:
https://eauto.si/metron-shop/product/ty ... a-3-phase/#
Post by antiscab » Sat, 17 Nov 2018, 08:22
Or this one, again, just need to swap the 3 phase plug for an Australian one
ZENCAR EVSE 10 16 20 24 32A adjustable CEE 5 Schuko adapter plug IEC62196 Type 2 5M cable Electric Car ev Charging cable Duosida
https://s.click.aliexpress.com/e/cEJGXzT7
Bryce
Real Name: Bryce Gaton
Re: Type 2 charge leads: Caveat emptor
Post by Bryce » Sun, 18 Nov 2018, 06:41
Hi all - would like to add a note of caution that built-in RCD protection is listed as 'optional'. IF you were thinking about ordering one - you must order it with Type B RCD protection.
As for switching 16A currents without a decent sized relay to be seen - seems to me a rather unlikely candidate for a long-lived, reliable item.
BTW, certification of electrical equipment for Euro conformity seems dodgy to me: date of 'first fixing of CE label' is 2012, and only refers to the cable - not the actual constructed lead!!?? Mind-you they do add a small asterisk to note that it applies only to the lead, not the whole item. That makes it SO much more trustworthy ....
All-in-all, not sure I'd 'touch one with a 40 foot pole' (preferably an insulated one too) as the saying goes.
Bryce
AEVA Vic Branch Secretary
Selling: 2011 Leaf
Past drive: 2011 Blade Getz
