Tritium fast chargers
Re: Tritium fast chargers
jonescg wrote: Tue, 28 Jan 2020, 08:46 Or some scallywag filled the inside of the case with butane and dropped a match?
I wondered about sabotage as well, but from the report:
  • "A vehicle was disconnecting from the ChargeNet station when it "blew apart", a Fire and Emergency New Zealand (Fenz) spokesman said."
Unless someone set up something with a timer or it just needed a spark... it just seems unlikely to me.
Tesla’s seem to have error 74 authentication issues at UWA veefil dc.
Many Tesla owners have to un/plug at least 3 times.
According to Ant Day,
No error 74 issue nor wait to start charging after tagging with his Kona.
Perhaps this can be a clue to circontrol QPC trio Tesla dc issues ?
2020 Model 3 SR+ - Delivered Fri 17 Jan ‘20 - k kms 60
Ant has since updated that he had to Wait 15 secs for authentication.
One hunch is the pilot signal of the ccs2 connector is faulty?
This is what happened at circontrol Harvey and margaret river dces
The ccs2 Phoenix contact connectors dont seem That robust.
Perhaps this topic could be moved from “the lounge” to “charging infrastructure” group ?
g4qber wrote: Thu, 28 May 2020, 07:33 Perhaps this topic could be moved from “the lounge” to “charging infrastructure” group ?
Done.
Bennyr83
Real Name: Ben
Post by Bennyr83 »
I saw someone ask about issues with these chargers in other parts of the world, and yes they exist.
One of these chargers was just installed in my town last week in Ontario Canada. I happened to be in the parking lot when I saw the technician pull out the "now open" sign from his truck, so I figured I'd give it a try. After about a minute, I got Error 139.
Luckily the tech didn't drive off yet, and was able to fix it up pretty quick. Error 139 is a fault when one of the cooling fans is unable to kick in, and apparently the plug for this fan is in an inconvenient spot, and needs to be disconnected for quite a lot of internal service, and some tech's forget to plug it back in when they're done.
He popped off the back cover, and had it reconnected in a few seconds.
I would have thought that a system like this would run through a self-test when powering on to check all these things, but maybe they were monkeying with it after it was powered on.
The next day I came back to the same charger, and again after a minute got Error 64
No tech around this time, so I submitted a report through the charge network's app. Don't know what this one is, but I suspect it's also related to the cooling system since it happened at nearly the same amount of charge time.
2 days later I tried the same charger and had no problems over a 30 minute charge.
EVTorque
Post by EVTorque »
g4qber wrote: Sun, 03 Nov 2019, 05:46 Error 32 at gwelup Veefil reported by model 3
Error 39 then permanently stuck on error 131 when trying to charge with imiev
Error 32: Description: Regulation issue with the charger while charging a CCS vehicle Likely Reason: Could not respond to changing grid conditions Resolution: Return plug to charger, remote charger reset and try again
Error: 39 Description: 480V 3 phase supply exceeded limits: <432V or >528V or <55Hz or >65Hz Likely Reason: Short glitch in power OR 3 phase power is lost OR Internal RCD tripped OR Internal breaker tripped Resolution: Return plug to charger, remote charger reset, if this clears the area if must have been only a short glitch that cause the error, if it does not clear please refer the issue to Tritium.
Error 32 occurred once at
Lake Grace
29 Stubbs St, Lake Grace WA 6353, Australia
https://www.plugshare.com/location/268279
Initial errors at gwelup nov ‘19
Veefil status codes
DOC.011_ Status Codes for Veefil-RT.pdf
(403.78 KiB) Downloaded 115 times
UWA DC dead. error 353. Not listed
praxidice
Post by praxidice »
According to Tritium blurb 'In addition to four fast-charging units in Brisbane (at Fortitude Valley, Coorparoo and St Lucia) eight further fast chargers will link popular destinations in the region (Noosa, Sunshine Coast, Caboolture/Burpengary, Ipswich, Toowoomba, Cararra/Southport, Coolangata/Tweed, Byron).'
To date I have seen nothing happen. Perhaps they were referring to the defunct / removed Brisbane BMW DCFC, the one at UQ and the state government ones at Toowoomba, Helenvale and Bilinga .. dunno about Coorparoo, Ipswich, Noosa, Caboolture and Carrara though.
praxidice wrote: Tue, 17 Nov 2020, 04:57 To date I have seen nothing happen.
There is plenty happening at the moment. The Queensland Electric Super Highway stage two accounts for a few (e.g. Ipswich), Evie is building out their network (e.g. Buderim, Noosaville). Check out plugshare.
praxidice
Post by praxidice »
coulomb wrote: Tue, 17 Nov 2020, 09:21
Certainly a few more scattered around since the last time I checked although too many Tesla ones for my liking. I've always found them more trouble than they are worth. Its a pity that the interests of non-Teslarti aren't promoted more extensively. Thankfully it looks like the next round of government ones are finally getting rolled out with common or garden variety connections. Also encouraging that some country pubs have realized even a 10 amp socket is likely to attract business. I believe there is plenty of scope for more of those.
brunohill
Real Name: Phil
Post by brunohill »
praxidice wrote: Wed, 18 Nov 2020, 07:37
Yeah Mate, That's what we need. Just lots of 3 phase country pubs.
New modular chargers announced yesterday...RTM75 looks the goods.
https://youtu.be/z02MbZ2aneU
praxidice
Post by praxidice »
brunohill wrote: Wed, 18 Nov 2020, 22:57
Three phase is pushing it ... I don't recall even one country pub in my travels that was so equipped. Showgrounds are a different situation though
Knutsford St Parking/Charging
Knutsford Street, Fremantle WA 6160, Australia
https://www.plugshare.com/location/287149
Not for public use yet - gated
The Kodja Place & Kojonup Visitor Centre
143 Albany Hwy, Kojonup WA 6395, Australia
https://www.plugshare.com/location/284816
Ex white gum valley dc now with CCS2 plug
