Model 3 Charging options in WA
Tesla EVs Interest Group
photomac
Real Name: Matthew Clifton
Post by photomac »
Is there an issue using the RAC EV Highway? When I look at this website it suggests it will not be possible. https://jetcharge.com.au/resources/tool ... o-you-need
Yes,   we can.   Image
Hyundai Kona 64 v1 Sept 2019 onward. 00016 up to 20000+
Re: Model 3 Charging options in WA
Post by reecho »
Some stations have been converted to CCS2. Check Plugshare for info...
photomac
Post by photomac »
reecho wrote: Wed, 17 Jul 2019, 20:34 Some stations have been converted to CCS2. Check Plugshare for info...
Thanks Reecho, that rings a bell from a few EV meetings ago.
Yes,   we can.   Image
Post by g4qber »
Harvey, Bunbury, Busselton, Dunsborough changed to ccs2
Others waiting on council funding.
$2500 per location to upgrade.
2020 Model 3 SR+ - Delivered Fri 17 Jan ‘20 - k kms 76
Presumably you could still charge from the type 2 cable with the 22kw on board charger. Not as quick, but won't leave you stranded.
photomac
Post by photomac »
I found this mobile charger, affirmations from some postings on these forum pages, whereby 1.5 to 22kW rate from GPO to 32A3P is feasible. Based upon my run from Perth to Esperance and back in LEAF v2.0 the available 32A3P sockets and Tesla destination chargers the sojourn would be worry free.
https://store.jetcharge.com.au/products ... b16a&_ss=r
Yes,   we can.   Image
Post by g4qber »
Model 3 only has 16.5kw AC onboard charger
photomac
Post by photomac »
g4qber wrote: Fri, 19 Jul 2019, 10:15 Model 3 only has 16.5kw AC onboard charger
Dang - even lower at 11kW
https://www.tesla.com/en_AU/support/hom ... rd-charger
Which yields estimates to be ave 70km to 83km per hour. ( 15.6kWh - 13.0kWh / 100km )
Yes,   we can.   Image
Post by reecho »
The superchargers at Eaton have been modified now with CCS2 connectors. So there's that...
Post by g4qber »
