LONG DISTANCES IN A BLADE
Randall679
Real Name: Randall Berger
Post by Randall679 » Sat, 28 Jul 2018, 06:34
Newbie Question: Is it possible to range extend a Blade by carrying a little generator in the boot?
I realise this is probably a dumb question ... I want to travel from Sydney to Melbourne. There don't seem to be enough public charging stations yet to make this a breeze. I know some people just pay to park near a powerpoint. I have the PlugShare app ... is there a more up to date one?
Re: LONG DISTANCES IN A BLADE
Post by jonescg » Sat, 28 Jul 2018, 09:00
Plugshare is probably the most up-to-date list there is. If you take a 3 phase to single phase adapter you can access a few more charge points.
The generator is probably unnecessary, and besides it takes up a lot of space.
Post by antiscab » Sat, 28 Jul 2018, 11:53
For obvious reasons, don't run the gen set while you're driving.
How much range do you have? What version of electron do you have?
2011 Blade Electron mk6
2007 vectrix - 145'000km
1998 Prius - needs batt
Randall679
Post by Randall679 » Sat, 28 Jul 2018, 17:05
No, I wouldn't be running the genni while driving! I just thought there are gaps in the PlugShare network. I could stop, boil the billy and charge with the generator.
It only has a range of 75-80kms. Not sure this version ... it is a 2009, but has had an "upgrade" ...
I live in Castlemaine where they were built and some of the original mob still live here... they will advise.
I just didn't want to truck it all the way home ... Save $650 ...
Post by mikedufty » Sat, 28 Jul 2018, 23:01
By my estimate it would take you 5 days or so if you could find optimal charging points. You'd have to really want to drive it.
4Springs
Post by 4Springs » Sun, 29 Jul 2018, 06:58
Find out what current the Blade charger draws. Then check just how "little" a generator is that will supply that current continuously. Generators are often sold on the peak power output, but you should be able to find the continuous rating there somewhere.
Randall679
Post by Randall679 » Sun, 12 Aug 2018, 16:13
That makes a whole lot of sense ... the 3 phase to single phase adapter ... does it charge any faster that just a normal power point? I have three phase in my Garage in Castlemaine ... I think they were going to run a kiln or a lathe.
Randall679
Post by Randall679 » Sun, 12 Aug 2018, 16:15
I have decided to challenge myself and drive 1000kms back to Castlemaine.
Will the Tesla charging stations get bolshi and not allow me to charge, even if I pay and have an adapter?
Randall679
Post by Randall679 » Sun, 12 Aug 2018, 16:24
How long does it take to charge a Blade?
Post by jonescg » Sun, 12 Aug 2018, 17:23
The three phase adapter only allows you to access single phase to supply the on board charger. It won't charge any faster, it just gives you more options.
Randall679
Post by Randall679 » Sat, 18 Aug 2018, 08:58
I got a three phase adapter ... good suggestion ...
Randall679
Post by Randall679 » Sat, 18 Aug 2018, 09:01
Well, that would be one way to get to know my EV!
