repair of broken auxillary drive motor shaft
Posted: Wed, 07 Aug 2013, 16:27
Broken auxiliary drive motor shaft.
Symptom: sudden heavy steering and car even quieter than usual!
Diagnosis: missing shaft, pulley and belts. (Fell out on road. Was able to find all after a bit of searching though
Suggested remedy:
Replace armature
Upgrade shaft diameter to 20mm (from 16mm)
Job description:
Unplug aux drive motor power and encoder leads from mini controller;
Unbolt aux drive motor (4 bolts);
Drop off motor for rebuild;
Get either old pulley re-machined to new pulley diameter or get new one made (I did the latter).
Reinstallation notes:
Pay careful attention to:
- Motor is running in correct direction (clockwise looking at the pulley) – check this before connecting belt. If running wrong way – see addendum/note below;
- lining up pulley with steering pump and A/C;
- proper tensioning of steering belt (can be a bit tricky as there is no tensioning arrangement for steering pump, unlike A/C, except to move the drive motor).
Parts suppliers:
Aux drive motor manufacturer: EMP, Bayswater (they can also modify the old pulley if it does not get lost when falling off!);
Engineering works for machining of new pulley if desired/required (mine had some wear and gravel rash, so replaced it).
Addendum/note:
In my case, the aux motor was running backwards after it came back. With a Seba 600 drive, this is easily rectified by using the ‘hidden’ keypad inside the controller – but careful attention must be paid to opening and resealing the controller box. Contact me for details. Earlier controllers require the swapping of a ‘jumper’ contact. Either way, Seba, (in Dandenong, Melbourne), are very helpful.
Suggested remedy:
Replace armature
Job description:
Parts suppliers:
Addendum/note:
