Page 5 of 5
Posted: Wed, 19 Mar 2014, 14:51
by g4qber
plugged in & out 3x
Posted: Mon, 14 Apr 2014, 13:08
by g4qber
had to reset @ meter box.
Posted: Sat, 17 May 2014, 20:13
by g4qber
Posted: Thu, 11 Sep 2014, 00:47
by g4qber
Posted: Sun, 21 Dec 2014, 23:03
by g4qber
Posted: Tue, 24 Mar 2015, 14:45
by g4qber
Posted: Tue, 24 Mar 2015, 16:25
Posted: Mon, 31 Oct 2016, 13:46
by g4qber
Posted: Sun, 14 Jan 2018, 07:52
by Peter C in Canberra
Posted: Sun, 14 Jan 2018, 11:53
by g4qber
Hi peter C
Posted: Sat, 12 May 2018, 11:17
Any solution yet?
Posted: Sat, 12 May 2018, 14:12
by rhills
Hi Peter,
HTH,
Posted: Sat, 12 May 2018, 20:30
by g4qber
Solution
Posted: Sun, 13 May 2018, 14:26
Hi Peter,
HTH,
I use the Volt EVSE with my Mitsubishi iMiEV and it has never tripped. At home I use the iMIEV EVSE for both cars and the Volt trips just often enough to be annoying but the iMiEV never trips. My conclusion, like the one earlier in the thread, is that it is the Volt itself, not the Volt EVSE that is causing RCDs to trip itermittently.
Posted: Sun, 13 May 2018, 15:40
by rhills
Hi Peter,
My experience is obviously quite different from yours as we don't own a Volt. Maybe our EVSE (which I purchased from @g4qber with full disclosure about the issues he'd experienced with it) is faulty and it's a different problem from yours...
Posted: Mon, 14 May 2018, 20:53
Any solution yet? ... I am wondering if it is worth getting a portable in-line RCD cord? My thought is to have that trip where it affects only the car and I can readily reset it to have another go at starting charging. With luck it might be slightly more sensitive than others so it goes first?
I got a 2m cord from Jaycar with an RCD device in-line and experimented today. Sometimes it tripped, sometimes it didn't but the house RCD always tripped when the cord tripped. Sadly, the cord tripping did not save a trip to the meter box to reset the RCD there.
Posted: Tue, 15 May 2018, 05:16
by g4qber
I have a solution.
Possibly
This is what I did.
Posted: Tue, 15 May 2018, 06:39
I have a solution. Buy the smallest wallbox unit you can find...And wire is up for luggable use...My layperson’s Reason being that wallboxes don’t have rcds.
Posted: Tue, 15 May 2018, 07:48
by g4qber
Completely agree with you.
I’m not an electrician
But
Posted: Tue, 15 May 2018, 08:57
But The issue may be having 2 rcds in series...
Posted: Tue, 15 May 2018, 16:11
by g4qber
Posted: Tue, 15 May 2018, 16:18
Posted: Tue, 15 May 2018, 16:33
by g4qber
Posted: Tue, 15 May 2018, 17:08
Posted: Tue, 15 May 2018, 19:50
by g4qber
