Hello everybody,
best wishes for a happy, healthy and prosperous 2021.
I have now a bit more data to play with.
coulomb wrote: ↑Sun, 20 Dec 2020, 07:56
As for BMU data list items 23 and 24, as you probably know, 23 is the estimated capacity that gets reset to 48.0 Ah and comes down rapidly when the BMU detects "anomolous" behaviour (actually due to the changed chemistry)
this value has already steadily dropped to 46.90 Ah, no idea if because of an inbuilt reduction value for new cells or if the BMS was just confused.
and 24 is just the present estimated Ah remaining on which SOC is based. It presumably starts at the same value as item 23 when the battery is deemed to be full, and reduces (or increases) as integrated Ah are measured going out (or into) the battery.
BMU data list item 27 is "Charge current integrated value". I am puzzled with this as it has not changed from 25.70 Ah even though the Ah charged and /or discharged from full to empty varied widely.So really I have no idea what it means.
coulomb wrote: ↑Sun, 20 Dec 2020, 07:56That's obviously where I saw the 60 Ah maximum.
Thanks for posting that; it has only just dawned on me that this is the reason that all the various scanner tools agree so closely on their descriptions of the data list items. It comes from Mitsubishi themselves. I was getting an idea at one point that these somehow are readable from the BMS itself.
For an unknown reason the new scanner refuses now to read the EV_ECU , that is where by fluke or accident I reset the months since battery install to zero, I did see this increasing to about .5 or so after a couple of weeks (in line with the decrease of the estimated capacity value item 23 ).
So far I traveled 748 km with the new cells.
A couple of times (both during warm weather, I was able to get above 70 resp 80 km range.
All the other times the real life range was between 50 and 60.
I am sure the BMS is not able to overcome the big discrepancy in cell capacity or variation of cell charge behavior. In an earlier post I wrote that the cell balance behavior of the LEV50Ns is the same as the 60Ah NMC-LIYUANs at the start of charging at low SoC, I can confirm that this is also the case at near full. The difference is that the LEV50 high volt cell(s) are within 0.01 V or better all the way from bottom to top where as the 60Ah NMC-LIYUAN cells are 0.04 V with short lived moments of 0.03V. Discharging is even more pronounced, at full tank and modestly accelerating (~50 A) low volt cell drops up to 0.2 V below top V cell,increasing to 0.4V when tank is half empty. At rest they bounce back to 0.04 or 0.05 difference.
I am contemplating to pay Mitsubishi to do the PROCEDURE FOR SMOOTHING CELL VOLTAGE.
Correct me if I'm wrong,I assume this means balancing the cells. But where? Top ,middle or bottom? Since I had the cells balanced ( 3.985 / 3.992 V) before charging them as a pack the first time, I hold no great hope that it will fix the problem.
One more anomaly is getting more pronounced.
Yesterday I drove until two bars. Then I turned on the heater full blast until the fuel gauge was empty and GoM 2 km. Let it rest for 40 minutes. SoC 10.50% (control),11.5%(display),
3.65 V(44),3.61 V(2)
Charged to "full" ,13.18 kWh of the wall in 356 minutes, disconnect cord.
46.90 Ah (item 23) 43.60Ah (24),78.5% (c),86%(d), total 359.7 V . RR (GoM) 108km, fuel gauge14 bars.
Let it rest for a while and kept checking to find SoC increased a bit, total 359.4 V ,GoM now 117km ,fuel gauge 15 bar.
This morning I checked again to find State of charge 93% (C),96%(D), max and min cell V 4.09 resp 4.06, total 359.4 V ,GoM now 127 km and fuel gauge 16 bar!
One mystery after another!
