iMiev Recall notice
PiMan
Real Name: Simon
Re: iMiev Recall notice
Post by PiMan » Tue, 15 May 2018, 10:10
nuggetgalore wrote:
Mon, 07 May 2018, 08:16
Not being "ready" should not allow the gear stick to get out of park.
There has to be a way to get it out of park without power (and therefore not Ready), or else it becomes too difficult to move if you fully run out of charge. Once last year I ran out of charge late at night and decided to wait until morning to get a tow, so I pushed it into a nearby carpark. The next morning I was able to put it from park into neutral so it could be rolled into position for the truck.
Even making it so that it can't leave park while plugged in wouldn't work, because if there is a software or hardware issue that causes the car to think it is plugged in when it is not, then you couldn't roll it easily to get it to someone who knows how to repair it.
Post by mikedufty » Tue, 15 May 2018, 11:55
In ICE cars you have to pull off a panel and stick a screwdriver in the hole to release it from park without power. A similar setup could work for EV for those rare emergency cases.
Post by g4qber » Tue, 15 May 2018, 12:16
On my 2011 imiev.
If key is in acc position, I can press the foot brake and then change out from park, else gearshift is locked in park
2011 will not go info Ready mode unless Imiev is in park with plug out
2011 will not go into ready mode if plug (powered or not) is in
:roll: 2011 i-MiEV - 151 kms September 2018
nuggetgalore
Real Name: Andreas Tobler
Post by nuggetgalore » Tue, 15 May 2018, 18:59
On my 2011 imiev.
Has your 2011 the keyless entry and keyless start knob like the 2010 or the physical key like the 2012? Has it the inbuilt navigator or just a car radio?
I also wonder if it already has the LEV50 N cells like the 2012.
tinker
Post by g4qber » Tue, 15 May 2018, 22:53
2011+ imievs went back to key method.
Had original rubbish sat nav . I’ve upgraded to AVN 827 GA thanks to reecho.
New sat nav is the reason I’m keeping the Imiev for now.
Has LEV 50 N since I changed the pack in December
Didn’t know that the 2012 has LEV 50 N cells.
nuggetgalore
Post by nuggetgalore » Wed, 16 May 2018, 21:17
The only reason I believe the 2012 has the "N" cells is because I read articles telling that Yuasa had a lot of complaints with the LEV50s and made improvements that supposedly were used for the 2012 iMiEVs.
tinker
