Imiev measured data
Imiev measured data
Post by offgridQLD » Fri, 12 Sep 2014, 02:39
Interesting thoughts. I'm sure they all play a part and have some effect.
Though I feel the slight gains and losses in elevation have the biggest effect on consumption that trying to pick up on air pressure fluctuation or wet patches on a public road would be near imposable (given that no roads are completely flat)
I bit like going to a rock concert and trying to pick out the person whispering to them self.
Hot weather can increase the performance of a EV as the battery's perform a better. Skewing the results a little.
It's amazing how we can pick up on small things that effect consumption in a EV with very limited energy storage. Small things are just lost in the rounding with a ICE car.Driving a EV most likely makes one a more efficient Ice driver to.
Imiev measured data
Post by g4qber » Sun, 14 Sep 2014, 17:03
http://www.commutercars.co.nz/buy-lease-rent.html
Look like my estimate that I've been mentioning to people I meet is correct.
16kWh = 100km range
2011 i-MiEV - k kms 183
Imiev measured data
Post by offgridQLD » Sun, 14 Sep 2014, 17:18
No way for the imiev flat road no wind is way less than 160whr -km. 16kw is the first line on the power meter. I sit at 100kph way under that mark. I think I did a test run and showed the results a while back doing a 40km stretch loged on canion. Sitting at 100kph constant and it was from memory about 125whr -km .
Malm
Imiev measured data
Post by Malm » Mon, 15 Sep 2014, 00:26
Well, I don't use math formulas or complicated thoughts. I just drive the car and see what happens. And what I see is that with rain I get less autonomy. I believe this is a result of more friction of the tires with the surface.
Real Name: Richard Baird
Imiev measured data
Post by reecho » Thu, 18 Sep 2014, 05:25
Android radio has arrived and now installed.
Canion works ......after a side load.
Very impressed so far, even with a few niggles...
DkubusEV
Real Name: Mike
Re: Imiev measured data
Post by DkubusEV » Sat, 21 Jul 2018, 22:34
Hi I just wanted to ask if you have any info on where I can get one of these head units in Australia?
Cheers.
Just add lightness and reduce drag.
