Kona (10A) standard EVSE not working on Leaf
Nissan EV Interest Group
doug
Real Name: Doug
Post by doug »
I bought a spare Kona EVSE, with the intention of lending it to my friend´s to use on their Leaf. Unfortunately, it seems to initially connect, but then drop out.
Anyone know why? The Charger is a Yuka, standard fitment to a Kona.
(Regards, Doug, a Kona owner)
Re: Kona (10A) standard EVSE not working on Leaf
is it a new leaf? or the older gen 1 leaf?
brunohill
Real Name: Phil
Post by brunohill »
My guess is, it is a new LEAF, or else the plug would not fit.
doug
Real Name: Doug
Post by doug »
Yes, Gen 2 Leaf, only few months old.
doug wrote: Wed, 30 Sep 2020, 16:43 Hi,
Interesting not working with Leaf. Have to try mine on a non Hyundai EV myself.
What was the EVSE worth from Hyundai Doug?
The MMAU ones were bonkers pricing.
https://forums.aeva.asn.au/viewtopic.ph ... vse#p76914
Type 1 EVSEes
Mitsubishi $1550
Nissan $3410
Holden $350
Nissan and Mitsubishi want to encourage owners to get a wallbox instead.
2020 Model 3 SR+ - Delivered Fri 17 Jan ‘20 - k kms 60
doug
Real Name: Doug
Post by doug »
Thanks all. I bought this one s/h for my friend with a Leaf. I will try running it up on the OpenEVSE emulator (which I have).
Bryce
Real Name: Bryce Gaton
Post by Bryce »
Hmmm. Best l try the Kona portable (Mode 2) evse on the new Zoe. .. might be a while before the Zoe needs a charge though. (It came new at 70% charged from the dealer and we are in Melbourne ...! )
Bryce
AEVA Vic vice-chair
Bryce
Post by Bryce »
Yep - just tried the Kona portable EVSE on the Zoe. Works perfectly.
My Mode 3 (fixed 32A) was a bit cranky with the new Zoe though - took a few tries to get the EVSE to talk nicely to the car. (And the Zoe is now pulling almost 8kW from my 7.4kW EVSE ... the vagaries of modern electronics ...;-)
Bryce
AEVA Vic vice-chair
doug
Real Name: Doug
Post by doug »
Sorted problem: I was not aware that the offending Leaf was set to charge Off-Peak. Set to Immediate & all OK!
(So Kona charger does work with Leaf)
Bryce
Post by Bryce »
BTW: if you want to do a one-off override of the off-peak setting in an older Leaf, hit the override button AFTER you plug the Leaf in. (Took me AGES to work that one out!)
Bryce
AEVA Vic vice-chair
