Page 2 of 3
Re: Non OEM Leaf battery upgrade?
Posted: Tue, 29 Jan 2019, 20:35
by brunohill
192 E63 LG Batteries (the ones Francisco is using) can be made to fit in a leaf battery box. I guess that makes the battery pack twice the original capacity.
Possibly premade packs. 10 packs x 18 batteries and 2 packs of 6 x batteries
Posted: Tue, 29 Jan 2019, 21:12
by jonescg
Yeah for sure - the energy density of those cells is very impressive.
I'm just trying to find the quickest approach and I think prismatics would be it. I reckon you could also use 18650 cells and a Tesla-style cooling loop, but it's all just weeks and weeks of work. My aim is to swap them out in a day if possible.
Posted: Tue, 29 Jan 2019, 21:18
by brunohill
jonescg wrote: Fri, 11 Jan 2019, 13:06 https://www.youtube.com/watch?v=d-ka4-mG_0I
In this video the guy explains how retaining the vehicle's original BMS was the easiest way to keep the vehicle's onboard computer happy.
So I might try and re-pack a Leaf battery with a new BMS and wiring, but have it so you can swap the BMS at the last minute.
Looks like this confirms the problem and provides the answer http://evsenhanced.com/products/hv-batt ... ring-tool/
Posted: Tue, 02 Jul 2019, 18:28
by brunohill
I am not sure how his extender battery boxes would go in the sunny summers here but his experiments and CANbus knowledge would sure be a useful resource.
https://www.youtube.com/watch?v=MC1NBwZICrQ
Posted: Wed, 24 Jul 2019, 15:35
by jonescg
Now this looks very promising!
Posted: Wed, 24 Jul 2019, 23:25
by antiscab
Blimey, that's amazing. 44kwh.
I wonder what cells they're using
Posted: Thu, 25 Jul 2019, 05:01
by brendon_m
Going by what he said they are LG chem pouch cells that are "numpt" kwh
But the box says 170wh
Posted: Thu, 25 Jul 2019, 11:32
by francisco.shi
They are probably the LG 63Ah.
They are the only cells that I know of that have the terminals on opposite sides. I have been looking for other pouch cells with terminals on opposite sides and I haven't been able to find any.
Posted: Thu, 25 Jul 2019, 12:07
by brendon_m
170wh at 3.6v (my guess is they are ncm cells because they use the original bms) is 47ah.
So 44kwh at 315v is 140ah that makes it 88s3p
Posted: Thu, 25 Jul 2019, 12:26
by francisco.shi
At 3:33 on the video you can see the cells with a size reference and the text. I can't see the part numbers but they look exactly the same as the LG63 cells I have and if they are LG they will be the 63Ah because the 63Ah are the only cells LG makes that have the terminals on opposite sides.
Posted: Thu, 25 Jul 2019, 12:37
by jonescg
I see 179 Wh on the side of the box, but yes I suspect they are the LG63 cells. A Leaf needs multiples of 96 of them.
Posted: Thu, 25 Jul 2019, 12:41
by brendon_m
So 96s2p of 3.6v 63ah cells gives 44kwh
Posted: Thu, 25 Jul 2019, 21:54
by brunohill
bruno hill
bruno hill
12 hours ago
@Oid Polar Are they LG E63 batteries?
Oid Polar
Oid Polar
7 hours ago
@bruno hill out of the availability list from here: http://queenbattery.com.cn/our-products ... -cell.html yes, they are e63 - there are no alternatives made by LG Chem.
Posted: Sun, 01 Sep 2019, 02:30
by esyjam
I would also say definitely LG E63 Batteries.
Posted: Wed, 11 Sep 2019, 02:53
by esyjam
Testing Package has arrived. About 8Kwh of usable Energy.
Regards,
Posted: Sun, 15 Sep 2019, 12:07
by doggy
LG E63 are the same ones used in the Renault Zoe which has the same 96sp2 configuration and the same kWHrs (45, 41 usable, 40 claimed= Z.E.40)
Regds,
Posted: Sun, 19 Jan 2020, 11:11
by RV6
Hi Guys, I hope the upgrade is all going well. Have just purchased 24kw version leaf and intend to do an upgrade, be it a direct replacement with a larger genuine pack with a man in the middle CAN BUS adaptor ( thats if I can source a battery ) or failing that I will try to build my own pack. Was wondering how progress is going with the LG cells ?
Posted: Sat, 22 Feb 2020, 09:35
by brunohill
Posted: Sat, 22 Feb 2020, 10:29
by antiscab
so he cut the cans open to replace the pouch cells
That looks like a lot more effort than I would have thought necessary
Posted: Sat, 22 Feb 2020, 10:52
by brunohill
It may be easier than replacing the bus bars and BMS wiring. Less chance of making a wiring error also.
Posted: Thu, 27 Feb 2020, 20:22
by brunohill
There should even be 6 mm of room in the middle of the new nodule for a cooling plate. To fix the display you could use this... https://www.tindie.com/products/muxsan/ ... rt-rev-25/ once you work out how to program it.
Posted: Thu, 09 Apr 2020, 22:25
by brunohill
brunohill wrote: Sat, 22 Feb 2020, 09:35 Jesus will save your Nissan Leaf.
Another cell swap...
https://forococheselectricos.com/2020/0 ... de-lg.html
https://forococheselectricos.com/2020/0 ... uidos.html
... But if the BMS has not been reprogrammed to suit there cold be some issues.
https://www.youtube.com/watch?v=QefdMYBTXZ8
Posted: Thu, 09 Apr 2020, 22:53
by brunohill
An 18650 41 kWh replacement battery.
https://www.youtube.com/watch?v=gBWRZQv ... e=youtu.be
Posted: Sat, 25 Apr 2020, 23:14
by brunohill
Jesus, he has done it.
64 kWh LG chem battery upgrade for old LEAF
But I think he may have a few issues to resolve.
Posted: Sun, 26 Apr 2020, 04:48
by francisco.shi
The only problem is no cooling.
