Gabz wrote: ....
having the ability to apologize properly gets you out of a lot of trouble
Sooooooo true. Some apologies aren't worth the hot air used in them. Properly is the key. So true Gabz.
Gabz wrote: ....
there getting payed to be there and "use that power point" so walking inside to turn on the master switch is no biggy"Why incoviniance yourself (having to go to a central switch board every time you want to use your own outlet"
the first one he lives there and is paying body corp fees and so on but if he is going to use it every day then he should have talked to the body corp about it and there would be no problem as he could have arranged something firstg4qber wrote: here is a volt owner "stealing" leccy.
http://www.drive.com.au/motor-news/row- ... 1qox7.html
I love the comments.
and builders too
http://forums.whirlpool.net.au/archive/2168177
offgridQLD wrote: "on your reasoning may as well leave the tractor out on the field because its a pain and a wast of time walking all the way over to the shed to get it out to use it "
Yes I do just that as it is a pain and takes up room in the shed.I would need to find the remote for the shed door. Back it out, fill the shed with diesel fumes. Shut the roller door drive to where I want to mow.
It's been in the weather for most of it's 30 years it's a tractor not a RR silver shadow![]()
