Suzi Auto regen
For Queensland Members of the AEVA
Suzi Auto regen
Post by coulomb » Thu, 18 Feb 2010, 16:52
Gents,
at the February meeting, there was a Suzi Autos swift with a Chinese controller supposedly capable of regen, but with the regen disabled. I noted at the last minute before the meeting proper that the field seemed to be in series with the armature, but reversible.
I remember wondering why you would want a reversing contactor on a car that has a gearbox including reverse gear. I also remember someone (sorry, I can't remember who) claiming that regen is impossible with a series DC motor.
But maybe the two are connected: maybe this really is a series motor, and they use the reversing contactor for crude regen as well as actual reversing? After all, the reversing contactor is connected to the controller, so it could be reversing the field (when there is no motor current) as a preparation for regen. I assume it would be doing something like Otmar's regen page. Much of Otmar's problems were because the controller wouldn't quickly ramp up and down in duty cycle, since it wasn't designed for regen. But of course, the manufacturers could just incorporate it into their firmware.
I assumed that the regen controllers came with separately excited motors, and indeed they do, according to Goombi's motor selection page.
Maybe the manual for the two controllers is the same, and on the non-regen controllers, you just don't have the option of regen.
For a while there, I thought perhaps they had figured out a way to do almost seamless regen on a series motor, using the reversing contactor. But now I think it's just a misunderstanding. Comments welcome.
Electron
Suzi Auto regen
Post by Electron » Fri, 19 Feb 2010, 01:57
I believe that the controller in the Suzuki was a regen controller.
From looking at Goombi's motor selection page, it talks about a separately excited motor and the drawings show the armature and fields being separate. Most series motors have separate terminals for armature and fields. Is there something different in the motor winding or the brush position? The only thing I can think of is that in regen the motor is configured into shunt mode, which would give some regen braking. I know from experience with my Solo Electra, When you over drive a permanent magnet motor while connect to the battery it will act as a generator and put charge back into the battery.
Also from reading Goombi's web pages, I think the information has been written in another country and maybe in another language.
Ron
Electron
Suzi Auto regen
Post by Electron » Fri, 19 Feb 2010, 02:08
Just had a rethink and reread of the info about the regen motor. I believe that the regen motor is in fact a shunt motor not a series motor.
Was the motor in the Suzuki a series or shunt motor? If it is a series motor, that would explain the problem of the controller getting hot.
I also read the motor has a duty cycle of only 1 hr.
Ron
Suzi Auto regen
Post by coulomb » Fri, 19 Feb 2010, 04:24
Electron wrote: Was the motor in the Suzuki a series or shunt motor?
I looked but couldn't find the second set of terminals on the motor; they must have been hidden. [Edit: so I don't know.]
I don't think they'd have needed the very large reversing contactors on a separately excited motor. The diagram showed the field in series with the armature (while being reversible), but of course there is no guarantee that that page happens to correspond to the car we were looking at.
Suzi Auto regen
Post by antiscab » Fri, 19 Feb 2010, 10:57
the reversing contactors could be because the controller isn't 4-quadrant, as a sepex controller would be (im also guessing)
so for regen,
the armature could be connected direct online to the battery, and the field is powered by the controller for torque control (actually im planning on doing this at some point)
in general, a sepex motor will have much lighter field windings and more of them. since little amps at traction voltage is easy to deal with, unlike big amps at low voltage.
shunt motors are wired much the same as sep-ex motors (internally).
that doesn't stop you from running a series motor with seperate excitation, though armature reaction does limit what you can do (especially if the motor has been advanced).
motors with regen in mind tend to have interpoles (which reduce armature reaction all round)
those contactors may well have to switch under load if this is the case, and the user does not know how to utilise the setup.
so they would need to be fairly highly rated. (even a kilovac EV200 is only rated to ~100 cycles at 100A 180v break).
Suzi Auto regen
Post by coulomb » Fri, 19 Feb 2010, 14:30
antiscab wrote: those contactors may well have to switch under load if this is the case, ... so they would need to be fairly highly rated.
The reversing contactor is very large:
The reversing contactor is many times the size of the main contactor, and it higher (you can't really see in this photo) than the controller.
Ah, a bit of a giveaway: one of the reversing contactor's connections is marked A2. (D1 and D2 are field connections, according to the circuit I saw). So it's probably like this circuit (from a PDF on Goombi's page):
It looks as though the top black conduited load goes to D2, but it's a trick of perspective; it actually goes to the 12 V auxiliary battery.
Edit: Graeme did say that the reversing contactor "was just sitting there, unused". I assume he meant that it was only ever used in forward, never in reverse, so the controller was wired to always run forward. But maybe he means that D1 and D2 on the reversing contactor don't actually connect to the field of the motor. I sure wish I paid more attention now.
Suzi Auto regen
Post by coulomb » Fri, 19 Feb 2010, 14:57
antiscab wrote: so for regen,
Wow. Won't it be hard to make sure you get the field current just right? A bit off in the low direction, and you could draw massive current, and too high and you could attempt massive regen.
[Edit: THought I had high and low field around the wrong way. I think it's right now! Image .]
With the armature across the pack, there would be nothing to limit the current, apart from fuses and the like.
Suzi Auto regen
Post by antiscab » Fri, 19 Feb 2010, 19:57
i was thinking more along the lines of the controller not shutting down when motor rpm fell too far (can't get field current strong enough for output voltage to match unloaded pack voltage)
that wiring diagram would definately be for the series DC setup.
the reversing contactors would be physically larger, as their continuous current rating has to be higher (motor current > battery current)
they don't need terrific breaking capacity though, so open frame is fine.
to rewire that setup for regen,
you could wire the traction controller across just the field (most of the inductance is in the field so current control shouldn't be too much harder)
you could use the main contactor for connecting the battery to the armature (or even the reversing contactor).
all just musing of course.
accelerator mapping would be a bit different:
0 accel = 0 power
a little accel = *lots* power
a midway accel = little power
a bit more accel = a little braking
a lot more accel = lotsa braking
still musing of course, but that is one possible way of wiring.
Suzi Auto regen
Post by coulomb » Fri, 19 Feb 2010, 21:54
0 accel = 0 power
Um, shouldn't that read
0 accel = self destruct
No field, no back EMF, nothing to limit current, and armature across the pack.
Or presumably you'd have interlocks to prevent this (e.g. at very low or zero field, make sure the main contactor supplying the armature is open).
Of course, if you have access to the firmware source code and can reprogram it, you can make it natural (whatever that means for regen; there seems to be a standoff at present between the "must have coast" crowd and the "you'll prefer using only one foot once you get used to it" crowd).
Edit: parse error (mismatched parentheses)
Suzi Auto regen
Post by antiscab » Sat, 20 Feb 2010, 04:51
aha...yes
0 accel = magic smoke disappearing,
i was thinking in terms of mechanical power earlier :)
suziauto
Real Name: graeme Manietta
Suzi Auto regen
Post by suziauto » Mon, 01 Mar 2010, 23:38
the reverse contactor was to be used if there was no gearbox, direct drive. As we use the original gearbox there was no point wiring it in, its there just in case the builder wishes to incorporate it.
The motor is series not shunt.. .
I hope I have answered your q's..
cheers Graeme
PS.. 2000 suzuki van is next conversion.. should be able to install larger batteries..
Electron
Suzi Auto regen
Post by Electron » Tue, 02 Mar 2010, 02:07
I might be wrong, but a standard series motor is not suitable for regen.
There are 2 kits available, one is a series motor unit and other is a regen separately wound motor unit, the motors are different.
How can you use a series motor with a regen controller, or a separately wound motor with a series controller?
Whats in the Suzuki?
Ron
Suzi Auto regen
Post by coulomb » Tue, 02 Mar 2010, 04:38
Electron wrote: I might be wrong, but a standard series motor is not suitable for regen.
It's widely regarded as unsuitable, yes. But it's been done.
Yes, I realise that. But I thought Graeme said that this model was actually regen capable, and he chose to disable the regen.
I think now I simply misunderstood; I think he meant that there is a choice of kits, as you say.
I thought they had a milder form of regen available with clever use of the reversing contactor with a standard series motor and a standard series controller, with clever software. Separately, they offer "full" regen with the sepex controller and motor.
What's in the Suzuki?
As far as I know, it has a standard non-regen controller and series motor.
Let's let this thread die; the clever thing that I thought might be happening clearly isn't.
Edit: trivial wording
Jeff Owen
Real Name: Jeff Owen
Suzi Auto regen
Post by Jeff Owen » Tue, 02 Mar 2010, 17:45
Could there be some confusion between regen and plug braking?
Goombi
Real Name: Eugen
Suzi Auto regen
Post by Goombi » Sun, 07 Mar 2010, 23:11
Hi all,, Therer are indeed two types of motor one is Series the other
ò.Structure of Motor
1. The motor is a separate excited DC motor, mainly comprising a stator, rotor, brush cover and drive cover and other components.
There are also 2 different Controllers.
Series type is simply connecting to motor to rnn and Off
Regen is powering motor when taking foot OF THE PEDAL the motor switches polarity and becomes a dynamo and pushes charge to batteries
It is mostly done by the controller. Conclusion 2 types of DC motors and 2 types of Controllers to controll the motors
The mystery about the Suzuki is easy explained its a Series type motor and controller
Goombi
Real Name: Eugen
Suzi Auto regen
Post by Goombi » Sun, 07 Mar 2010, 23:15
It is possible to change Regen to Series motor but not the other way round each type needs its own controller.. The series type controller and motor you can view in EV Brumby web site
Goombi
Real Name: Eugen
Suzi Auto regen
Post by Goombi » Sun, 07 Mar 2010, 23:21
Sorry its the REGEN on Brumby site--- NOT Series woops
