Perth e-scooter recharging
Just had go ahead from Natalie O'shea (city of perth parking)
to charge e-scooters in the electric vehicle bays at city of Perth carparks
But note that one has to purchase a car ticket as it is a car bay.
And let the parking attendant know that Natalie has given the go ahead.
You may ring up 24 hours ahead to book a spot.
Please provide rego and time required.
Also if you are a regular you can also request a spot be reserved.
Eg Friday between 2-4.
You can also take pot luck, but the bays may be ICEd as they are not reserved bays like acrod ones.
The signage still say "electric car charging available"
But the PDF says "electric vehicle charging"
Hopefully there will be electric points installed in the motorcycle and bike bays one day.
http://www.cityofperthparking.com.au/si ... 290813.pdf
http://www.youtube.com/watch?v=VtkhKR0a-dA
vectrix charging via elektrobay bollard with a whitebox interface.
does anyone know how to make one?
http://www.tucsonev.com/ sells something similar
just has to be put in a box, with optional powerpoint really.
you could probably fit in inside an IP65 15A outdoor powerpoint box thinking about it
