need some help with igbt drivers please
drspastic
Real Name: ed
Post by drspastic » Tue, 07 Jun 2016, 01:38
hi, this is a bit off topic because i am building a pump drive for the smallholding but after trying the electronics forums to no practical use, i noticed you guys on this forum are legends in designing your own igbt drives.
cost is an issue and i believe i have most of the parts i need. there are 2 half bridge 600v 100a igbt bricks. there are 4 m57959l hybrid drivers, a pic micro making 50hz spwm and an inverted output.
im pretty experienced in electronics but this is my first time with igbt or high power. i know the drivers will need isolated psu but i need more info on exactly what i can get away with.
of course, its urgent now because my chinese 1500w blew smoke yesterday and now i have no irrigation. opening it revealed 3 caps blown off the pcb and the display pcb regulator a charred mess. also note the pcb said 1000w!
this will all be good practice as i have 3 more even bigger igbt bricks and a saab 9-5 aero with a main bearing crunched just gasping for a 3 phase motor!
Post by Richo » Tue, 07 Jun 2016, 21:46
Recom make dedicated IGBT driver DC/DC's.
The price difference isn't enough to worry about using the 1W.
Try something like RKZ-051509D
drspastic
Real Name: ed
Post by drspastic » Tue, 07 Jun 2016, 23:26
thanks but drat! i just ordered these last night before i saw your message:
B1209LS-1W 12V to9V converter DC DC power module converter 1000VDC Isolation
B1215LS-1W 12V to15V converter DC DC power module converter 1000VDC Isolation
i got 4 of each so everything is isolated! or it will be in 3 weeks when they arrive. the ones you quoted look better.
am i almost out of the woods yet though? i have igbt, drivers, psus soon, pic spwm.
Post by Richo » Wed, 08 Jun 2016, 21:00
Yep that'll work just the same.
4 of each ie isolating only the high side with a spare.
Post by Richo » Wed, 08 Jun 2016, 21:22
What are you using for current feed back?
For a cheap drive the ACS756SCA series or similar should be ok.
Post by antiscab » Thu, 09 Jun 2016, 22:47
If you're interested in AC, EV Shop have a tritium 165kva controller with a matching induction motor (4-pole ~70-80kg ish) going for $6k or there abouts
