0-10v throttle
Madmax
Real Name: Matt
0-10v throttle
Post by Madmax » Mon, 23 May 2016, 05:19
Hi all,
where/what is a good source for a 0-10v throttle?
cheers!
0-10v throttle
Post by jonescg » Mon, 23 May 2016, 20:08
Wouldn't any throttle work? They're just voltage dividers. Do yoy mean a 10 kOhm potentiometer?
0-10v throttle
Post by Richo » Mon, 23 May 2016, 20:30
There not all pots.
Half of them will be hall type which are 5V.
If you can find the pot type it should work on 10V
I'll assume you're wanting one for an Industrial VFD which generally use 10V.
http://www.evworks.com.au/ev-works-thro ... istive-typ
You will need to solder the third wire on for it to be suitable for a FVD.
Madmax
Real Name: Matt
0-10v throttle
Post by Madmax » Tue, 24 May 2016, 01:14
0-5V should also work (simply config the controller).
Richo, yes its for an industrial controller... I have a couple of Dunkermotoren BG75x50PI motors which have integral controllers that I'm testing for a project.
mortonpiers
Real Name: Piers Morton
0-10v throttle
Post by mortonpiers » Wed, 28 Dec 2016, 22:03
