Changing an induction motor voltage
Stiive
Post by Stiive » Wed, 14 Nov 2012, 14:26
cts_casemod wrote:
Johny wrote:
cts_casemod wrote:I need a 192Cell array and the BMS itself costs almost as much as the batteries themselves.
Have you looked into BMSs that handle 16 cells per board?
I have. The most simple ones are about 80$ each = 1300$ + Shipping + 20% VAT + Import taxes.
What I need is something "simple" with an output to an external contactor and without balancing, but I would like to have a reading of the individual cell voltages
If its something simple like that, your better off designing your own.
What exactly will the BMS be doing?
Rgds,
Stiive
Post by Johny » Wed, 14 Nov 2012, 14:38
What would be ideal for higher voltage pouch or Headway packs is a variation of Neville's BMS re-layed out for 16 cells per board.
If no shunting was really required then just leave the shunt resistors off the board.
viewtopic.php?title=low-cost-bms&t=2753
cts_casemod
Real Name: Carlos
Post by cts_casemod » Wed, 14 Nov 2012, 18:08
Johny wrote: What would be ideal for higher voltage pouch or Headway packs is a variation of Neville's BMS re-layed out for 16 cells per board.
I have asked him how to get those boards, actually is the best solution I have seen.
He said on an older post that depending on the memory present on the master it could hold a couple hundred cells ok, maybe I could use the same master and conect my 4 packs (I may not have the same pack on the car all the time) which would be just great!
I was wondering, Will I be able to modify the VFD to work with only 320V? Just in case I had a problem with the packs and wanted to limp back home using the remaining good/charged ones.
cts_casemod
Real Name: Carlos
Post by cts_casemod » Wed, 14 Nov 2012, 18:19
Stiive wrote:
cts_casemod wrote:
Johny wrote: Have you looked into BMSs that handle 16 cells per board?
I would like to have something like an analog multiplexer reading each cell using an optocoupler. The micro then would give me a reading that I could use to trigger the HVC and LVC and an alarm to indicate the battery was almost empty (Soc =<20%)
Using this method I could know if a cell was bad and where it was located on the pack.
Neville's BMS does all this with the option to disable the balancing which is very atractive.
My packs are removable (4x15Kg) so I will bring one home each time I use the car, so the Soc of the modules may not be the same.
ChrisRider
Real Name: Chris Rider
Post by ChrisRider » Tue, 15 Jan 2013, 22:25
I have a similar project coming up also, i wasnt sure if it was actually possible to physically change the induction motor voltage. Seems as though it may cost a bit in spare parts and materials, but i think it could be worth it as long as i dont break anything in the process, hehe
Resident Engineer at Reef Bikes
ale0502
Real Name: Alejandro
Post by ale0502 » Fri, 01 Apr 2016, 16:20
Hello everyone, this is my first time I write in this forum.
First of all sorry for my English, I'm from Argentina.
I'm working on an electric conversion of a car from a three-phase induction motor and a bank of lead acid batteries. I'm developing the controller and all the staff.
I read the forum and understand some things and not others, plus the use of the language that makes I have to ask.
My motor is 4Kw , 2870rpm , 380V / 220V , 14.4A / 8.3A , 18 slots.
My battery bank is 120V, so I would like to modify my motor to have the best possible power with the voltage available.
What dou you recommend?
Because is a 2-pole, I can only lower the operating voltage to half, being of 380/2 = 190V, is that true??.
thank you very much in advance for sharing all this with the community
Post by antiscab » Fri, 01 Apr 2016, 16:50
If you are very lucky, all 3 x 2 pole groups will be presently wired in series.
If that is the case, then you could rewire to parallel giving 190V star and 110V delta
2017 Renault zoe
2007 vectrix - 145'000km
Post by coulomb » Sat, 02 Apr 2016, 01:54
antiscab wrote: If that is the case, then you could rewire to parallel giving 190V star and 110V delta
I'm quite rusty on this stuff, but I think with 120 VDC you will only get about 80 VAC (line to line). So that would only be 73% of full voltage for the motor. So you'll only get to about 72% of rated speed. You'll need a lot of current to get any power from this motor.
It will be a challenge.
Post by Richo » Fri, 15 Apr 2016, 20:47
Mmm 2-pole isn't a great place to start.
The rewind would need to be ~50Vac to run on your 120V pack.
Peak ~5000RPM.
If your lucky you might get 20kW out of it.
Under 50kW the BLDC motors are probably a better option.
