car hoist
car hoist
Re: car hoist
Thank god it's 3 phase, otherwise I'd be trying to explain to my wife where I'm going to put a hoist and why I need it
Re: car hoist
single phase to 3-phase vsd is only like $200 brand new (hoist just goes up a bit slower)
Re: car hoist
brendon_m wrote: Tue, 27 Aug 2019, 12:41 Thank god it's 3 phase, otherwise I'd be trying to explain to my wife where I'm going to put a hoist and why I need it
GOLD!
francisco.shi
Real Name: Francisco
Re: car hoist
Post by francisco.shi »
You can change the wiring from star to delta and will run at the same speed.
And if you put a vfd you can adjust how fast it goes up so you can get very accurate positioning.
So better start working on your explanations.
Re: car hoist
Lalalalala, I'm not listening, lalalalalala
brunohill
Real Name: Phil
Re: car hoist
Post by brunohill »
You should be able to just sling a moke up a couple of gum trees. She'll be right mate! ;)
HuffnPuff
Real Name: HR
Re: car hoist
Post by HuffnPuff »
$600? Lucky my garage isn’t really tall enough for a hoist. Kinda defeats the purpose when you can’t get the vehicle much higher than a jack stand.
Re: car hoist
brunohill wrote: Tue, 27 Aug 2019, 23:36 You should be able to just sling a moke up a couple of gum trees. She'll be right mate! ;)
I normally just make sure I bend with my knees when I need to lift it up. Its just hard working with only 1 arm while the other is holding the car up in the air :D
Re: car hoist
HuffnPuff wrote: Wed, 28 Aug 2019, 05:21 $600? Lucky my garage isn’t really tall enough for a hoist. Kinda defeats the purpose when you can’t get the vehicle much higher than a jack stand.
I don't have the height for one either, my shed is a sea container and my garage is just a standard under the main roof carport. Maybe it could go out the front on the driveway, sort of a community hoist perhaps
Re: car hoist
put in a tall front of house shed to house the hoist?
extra points for also making more roof to put solar panels on :D
