Vectrix and assorted EV parts
Posted: Fri, 27 Jul 2018, 10:16
I've been collecting bits and pieces for years now, just been fleeced through a divorce and need to have a cleanup and get some funds back again.
All of this is in good working order.
I'm located in Newcastle, N.S.W but happy to ship via pack-n-send etc to get this to you at your expense. I've got a Ute as well so can deliver if you are close enough too.
Vectrix VX1 - $1500
Was my daily ride for ages, until I bought a petrol bike for longer trips when I got divorced (and actually had some freedom).
It was fitted with Nissan Leaf batteries, a full Fetcher/GGoodrum BMS system, 2KW Elcon charger + fan, Cycle Analyst, extra DC:DC converter that runs a HID
projection headlamp with a FastBright 35W ballast (not cheap, slow to light ballasts). Easily pulled 32Kw when seriously provoked.
The bad thing is that the batteries got drained by neglect. I've since removed them. They hold a charge but have too high internal resistance for EV applications
(Now being used for off-grid storage).
Everything is ready for a new set of batteries and just riding it. Currently unregistered.
144V Battery Bank and Charger, $1000
Elcon 2Kw charger set up for 13 series AGM batteries, and 13 50AH Eaton PWHR12200W4FR AGM batteries.
Great for someone who is building an EV on the cheap. I've been hoarding parts for ages. My plan was to use the Vectrix swingarm and build a delta trike, but never
got around to it.
Batteries test AS NEW in capacity and internal resistance, and handle 300A peaks fine. They were removed only a year into service from a UPS due to a single cell (in a 44S pack) failing.
The charger alone is worth $1000 (https://www.evworks.com.au/tc-charger-1 ... po4-charge) so this is a bargain!
Battery datasheet - http://lit.powerware.com/ll_download.as ... _Oct08.pdf
Vectrix Motor Controller, $350
This was a spare I kept for my bike. Installed to test, but never used for long on road. Its had a new Powerex PM300CLA060 fitted as it ate its original one's terminals.
Vectrix Swingarm, $350
Full swingarm + motor + rim + encoder. Has 1,200Klms on it. Bought for a project that never happened. The tyre on the rim is bald though (I swapped the good one onto the bike).
The encoder is unusual as it has both a sine/cosine output, and normal hall effect outputs, so it can be run easily with cheap commodity controllers.
MORE ITEMS BELOW - Can't post more than 6 photos at at time...
Vectrix VX1 - $1500
got around to it.
