Vectrix and assorted EV parts
- Real Name: Heath Young
I've been collecting bits and pieces for years now, just been fleeced through a divorce and need to have a cleanup and get some funds back again.
All of this is in good working order.
I'm located in Newcastle, N.S.W but happy to ship via pack-n-send etc to get this to you at your expense. I've got a Ute as well so can deliver if you are close enough too.
Vectrix VX1 - $1500
Was my daily ride for ages, until I bought a petrol bike for longer trips when I got divorced (and actually had some freedom).
It was fitted with Nissan Leaf batteries, a full Fetcher/GGoodrum BMS system, 2KW Elcon charger + fan, Cycle Analyst, extra DC:DC converter that runs a HID
projection headlamp with a FastBright 35W ballast (not cheap, slow to light ballasts). Easily pulled 32Kw when seriously provoked.
The bad thing is that the batteries got drained by neglect. I've since removed them. They hold a charge but have too high internal resistance for EV applications
(Now being used for off-grid storage).
Everything is ready for a new set of batteries and just riding it. Currently unregistered.
144V Battery Bank and Charger, $1000
Elcon 2Kw charger set up for 13 series AGM batteries, and 13 50AH Eaton PWHR12200W4FR AGM batteries.
Great for someone who is building an EV on the cheap. I've been hoarding parts for ages. My plan was to use the Vectrix swingarm and build a delta trike, but never
got around to it.
Batteries test AS NEW in capacity and internal resistance, and handle 300A peaks fine. They were removed only a year into service from a UPS due to a single cell (in a 44S pack) failing.
The charger alone is worth $1000 (https://www.evworks.com.au/tc-charger-1 ... po4-charge) so this is a bargain!
Battery datasheet - http://lit.powerware.com/ll_download.as ... _Oct08.pdf
Vectrix Motor Controller, $350
This was a spare I kept for my bike. Installed to test, but never used for long on road. Its had a new Powerex PM300CLA060 fitted as it ate its original one's terminals.
Vectrix Swingarm, $350
Full swingarm + motor + rim + encoder. Has 1,200Klms on it. Bought for a project that never happened. The tyre on the rim is bald though (I swapped the good one onto the bike).
The encoder is unusual as it has both a sine/cosine output, and normal hall effect outputs, so it can be run easily with cheap commodity controllers.
MORE ITEMS BELOW - Can't post more than 6 photos at at time...
Vectrix VX1 - $1500
got around to it.
Re: Vectrix and assorted EV parts
Vectrix Runke Charger $250
Standard 1500W charger removed when I fitted lithium Leaf Cells. 1200 klms old. In good working order.
150V Programmable voltage/current charger - $250
Really nice bit of gear, Adjustable from about 95-150V and 1-10A. High end programmable charger. It shows an error because the sense leads are disconnected, but
charges regardless. Its designed for free air cooling, but personally I usually run a 120mm fan on it.
http://imgusr.tradekey.com/images/uploa ... 3a189a.pdf - Datasheet
Pricey little buggers to buy too at $1K new!
https://wholesaler.alibaba.com/product- ... 85935.html
Vectrix IGBT - PM300CLA060. $200
Removed from a low Klm working controller (1,200klms) that had the firmware wiped during a failed update.
Ideal if you have a smoked IGBT. New these little buggers are $500 each(!)
MORE ITEMS BELOW...
MORE ITEMS BELOW...
12V 50AH Batteries - Eaton PWHR12200W4FR AGM batteries - $75 each
1 year old, test AS BRAND NEW. Never been used for anything but float charged in a UPS. Basically half-price. I have rather a few of these. Matched from the same batch for large series string use.
- Real Name: Jonathan Johnston
How many of the batteries do you have in total? Potentially interested in using them for off-grid storage.
I have 30 at least. I'll check for you. Happy to do a bulk price for you.
Depending on your budget I have a brand new in box SMA SBU5000 inverter + 2Kw of solar panels to go with those batteries.
- Real Name: Mark Winstanley
- AIM: 8 Hopkins Way
Hi Heath, Do you still have the programmable charger and the SMA inverter?
Cheers Mark
Cheers Mark
I do - I'll give you a ring on the number you provided at lunch today.
So it turns out the batteries in the Vectrix are actually OK, there was a loose busbar that was causing a high resistance joint.
I'll re-list this bike with updated information. I don't have the room in my garage to store it, nor the time to ride it since I have a 700cc gasser (boo hiss I know).
Hello is the MC and the charger still for sale?
Hi I am interested in the bike, i have sent you a message
Mick
2016 Tesla Model S 75
2014 JDM Nissan Leaf
Looking of a Vectrix Project
- Real Name: Matthew Lacey
I find myself chasing a Vectrix charger, if you still have one for sale?
- Real Name: Daniel Mulder
I have all the stuff from Heath, is it the Runke charger you are after?
I may be a bit slow replying as I a travelling.
Is the runke definitely working? If so, then yes please. Happy to wait till you're back
- Real Name: John Mascaro
Hi
Do you still have the Runke charger for sale.
Cheers John Mascaro
Cheers John Mascaro
I'm assuming that the bike has long been sold?
yes, to wovenrings, who has a spare charger
If you're looking for a Vectrix I am also shortly to have a leaf powered one up for sale. I am in Perth though
- Real Name: Pete
Hi
I am looking to a Vectrix charger do you still have it?
What else do you have left for the Vextrix?
Regards
Peter
Regards
Peter
- Real Name: Pete
Wanted Vectrix VX1 or a charger for Vextrix
where are you located Pete?
Best bet at the moment would be a 3.3kw TC Charger. They fit in place of the original.
Downside it ends up being around $1k, and you have to slow it down when not using a 15A powerpoint
I bought this bike and a lot these bits came with it, pm me and I will see if I have it.
