45 times 90AmpHr LiFePo cells, charger, BMS, plus
lachlanmac
Real Name: Lachlan Maclean
Post by lachlanmac » Fri, 13 Jul 2018, 17:50
I have had this advertised before and now the price for everything is $2000.
45 90 AmpHr Thundersky / Winston LiFePo cells plus another 2 cells.
A BMS system with module for each cell and a controller which will turn off charging and sound alarms etc.
A TC brand 144V charger (about 8 amps 240V draw)
50mm cables, crimp joints, spare cell connectors,
Contactor, ammeter shunt, and other bits and pieces
Cells are maybe half way through their usable life. Charger is reasonably new.
I live in Kallista, Victoria.
txt me on 0428549897. or email lachmac52@gmail.com.
This would be very good in an EV or as a PV battery system or just as a lot of 12V batteries (each cell is 3.2 V nominal so 4 cells is a pretty good second battery)
Lachlan
Re: 45 times 90AmpHr LiFePo cells, charger, BMS, plus
Post by jonescg » Fri, 13 Jul 2018, 19:44
Damn... If I wasn't in the process of buying a house I might have jumped at that!
Post by antiscab » Sat, 14 Jul 2018, 16:16
Pm sent
lachlanmac
Post by lachlanmac » Tue, 23 Oct 2018, 10:21
It has been sold
