I have had this advertised before and now the price for everything is $2000.
45 90 AmpHr Thundersky / Winston LiFePo cells plus another 2 cells.
A BMS system with module for each cell and a controller which will turn off charging and sound alarms etc.
A TC brand 144V charger (about 8 amps 240V draw)
50mm cables, crimp joints, spare cell connectors,
Contactor, ammeter shunt, and other bits and pieces
Cells are maybe half way through their usable life. Charger is reasonably new.
I live in Kallista, Victoria.
txt me on 0428549897. or email lachmac52@gmail.com.
This would be very good in an EV or as a PV battery system or just as a lot of 12V batteries (each cell is 3.2 V nominal so 4 cells is a pretty good second battery)
Lachlan
45 times 90AmpHr LiFePo cells, charger, BMS, plus
- Real Name: Lachlan Maclean
- jonescg
- Real Name: Chris Jones
Re: 45 times 90AmpHr LiFePo cells, charger, BMS, plus
Damn... If I wasn't in the process of buying a house I might have jumped at that!
Pm sent
2017 Renault zoe
2007 vectrix - 145'000km
2017 Renault zoe
It has been sold
