2008 Mazda 2 conversion - $9k - Perth
Post by antiscab » Sun, 12 Feb 2017, 05:14
Hi Guys,
I'm selling my 2008 Mazda 2 conversion
Originally converted by EV shop back in 2009
Since buying last year I have swapped the MC for a Zeva 1000A unit, installed a J1772 charge port and a DC charge/discharge port
specs:
70km range (would be way higher but battery is down on capacity)
41 x TS160Ah cells (actual capacity is 100Ah, limited by lowest capacity cell. not sure how much more the others have)
2.4kw charger (15A output)
charges from a standard 10A GPO
Impulse 9 motor
standard 5-speed gearbox with upgraded heavy duty clutch
Rego till June
pictures on my gumtree ad:
2008 mazda 2 EV
2017 Renault zoe
2007 vectrix - 145'000km
Post by antiscab » Sun, 12 Feb 2017, 05:23
The fellow who originally commissioned the conversion made a build log photo album, which will come with the car too
2017 Renault zoe
Post by antiscab » Fri, 19 May 2017, 15:04
Bump. asking price now $6000
2017 Renault zoe
Re: 2008 Mazda 2 conversion - $9k - Perth
Post by antiscab » Fri, 15 Sep 2017, 11:15
SOLD
2017 Renault zoe
