Set of Azure Dynamics parts + BMW E30 for sale
Post by a4x4kiwi » Sat, 28 Sep 2013, 00:13
Due to a change in priorities, I need to sell the parts I have gathered for my BMW E30 conversion.
These parts will suit any small to medium sized car conversion, or the E30 that is also for sale (see below). Using direct drive on the BMW the 0-100 time is calculated at about 7 seconds depending on final drive ratio. With a gearbox, even quicker.
All parts are located together in Sydney. You don’t have to worry about group buys, import duties and freight costs. I have done it all for you.
The price is $8500 for the complete set of parts. This is the all up cost including shipping etc. from around the world. If you add up these prices with similar parts from the EVTV store, it will come to about the same price, and you still have to ship the parts to Australia.
Shipping out of NSW can be quoted separately.
These parts have been selected especially to go drag racing and beat other 80’s - 90's cars such as the BMW E30. The idea is to use enough battery to provide just less than 400V at top of charge and sufficient amps to draw full power for 10 seconds. The high discharge ‘red’ headways are ideal. A little heavy, but fail safe, unlike prismatic and pouch cells.
This kit, in a light E30 or a Suzuki Cary will fly down the drag strip, or just have some fun at the lights.
Here is what you get:
Azure Dynamics / Siemens water cooled induction motor model 1PV5138-4WS24. This motor is good for about 100kW and 300 newton meters at 300 volts. I am sure it can be overclocked at least by 10%. Specs: http://store.evtv.me/proddetail.php?prod=1PV5135
Vaxo motor shaft coupling for attaching to a drive shaft or clutch plate if using a gearbox.
Azure Dynamics DMOC645 controller – Already Programmed (controllers usually come un-programmed and normally require a CAN programmer worth several hundred dollars to buy). This controller has an upper voltage limit of 400 volts. If you use 330v of batteries you will be able to increase the motor power and torque by about 10%. There is a lot of support for the motor and controller available from the ev.tv forums. http://store.evtv.me/proddetail.php?prod=DMOC645
TC Charger 2kW TCCH-312-5.5 Programmable up to 417V & 5.5A, CAN-Bus battery charger. I can even provide a working Arduino, LCD and CAN adaptor with source code to get you started.
Azure Dynamics air conditioning compressor with CAN bus commands documented. I spent quite some time locating the CAN documentation for this unit, saving you the pain. These are also used in the iMiEV in case you need to compare with a working unit.
2 x Azure Dynamics water pumps. One for motor and controller cooling, the other for the cabin heater.
12 v Brake vacuum pump x 2. One rotary vane as used in Volvos. One Azure Dynamics piston. Your choice which to use, and which to sell.
Brake vacuum switch – adjustable with hysteresis.
Stainless steel bottle for brake vacuum.
Azure Dynamics water heater. This is for heating the cabin of the vehicle and required for demisting the windows.
Set of male and female J1772 connectors for the charging. This is preferred as you can use a commercial charging station, or with the provided cable, charge at home.
2 x Kilovac contactors. http://store.evtv.me/proddetail.php?prod=EV200AAANA
High current MES-DEA 1000W DC-DC. This is a very professional unit rated at 60A output. Many are 40A or less and are simply not up to the task of driving the vehicles 12 volt electrics for any length of time at night with lights, fan and wipers running. This unit will run your 12 v electrics with all accessories running. http://www.metricmind.com/data/mes_dcdc.pdf
BMW Accelerator pedal. This is an awesome unit. Easy to mount and use with your driver interface. No more unreliable throttle pots.
Details of how to drive the various parts are located on my blog http://malfunction.faed.name
Just add a driver interface such as http://rechargecar.com/macchina, batteries and BMS. My preference is Headway batteries and Batrium BMS for ease of use and local support.
For a further 4k you can buy my white ’91 BMW 318i E30 to convert. This car is currently registered in NSW. It has been my daily driver for the last 3+ years. This car has no visible rust and is a pleasure to drive. The suspension is top notch, has new brakes all round and a M40 motor in great condition you can sell to recoup some of the cost. If you buy the car, I will also give you a factory manual steering rack so you don’t need to worry about a power steering pump. I will also include a Getrag 240 gearbox in case you want to use the output shaft or the gearbox. This also allows you to make an adapter plate before pulling the car apart.
If you buy the whole lot for $12,500, I can load up the car with the parts and deliver for free anywhere on the east coast and fly home.
Please phone 0409 601 747 or email [url=mailto:malcolm@faed.name]Malcolm@faed.name[/url] should you be interested.
Post by a4x4kiwi » Sun, 20 Oct 2013, 21:47
Bump. In case anyone is contemplating buying this kit, please feel free to get in touch.
Post by a4x4kiwi » Thu, 19 Dec 2013, 13:32
Who would like an awesome kit of EV parts for Christmas? Image
celectric
Real Name: Tim Bates
Post by celectric » Fri, 20 Dec 2013, 14:44
I have asked and a4x4kiwi is unwilling to split up his kit, but if anyone is interested in just the motor and controller, I am willing to take the rest of the parts and share the cost.
[It's a great motor, and I would buy it if I didn't have one already. Image ]
Post by a4x4kiwi » Wed, 30 Apr 2014, 02:44
Hi all,
I have listed the kit on Ebay to see if I get any bites.
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... 1392514558
Mal
Post by a4x4kiwi » Wed, 09 Jul 2014, 00:26
bump...
Bueller... Bueller
