Voltron-Evo; jonescg's new electric race bike
"When I let my clutch out I have reciprocating mass to help carry me off the line with an EV you may have peak torque but you don't have anything previously spinning.
This is both good and bad, good from the standpoint that don't have mass to invoke wheelies or wheel spin, but bad that you don't have mass to help move it initially off the line.
Perhaps because you don't have that reciprocating mass you could launch with more controller power for a faster ET."
This is something that I think is often overlooked when people get to hung up on the EV (Max torque from 0-RPM) spec that get thrown around a lot.
I tend to find it's impressive when displaying it through in gear acceleration of a EV vs off the line or even 60 foot times.
Off the line it takes a lot of Torque to match that savage rotating mass of a flywheel and crank spinning at 10,000rpm+ and saying hello to the clutch in a real hurry. So max torque at 0 rpm sounds great and all.
10,000rpm of rotating inertia being released suddenly is savage.
One of my favorite examples of how savage it can be off the line (watch his left foot on the clutch)Image https://www.youtube.com/watch?v=qAo95Z7MPpw
Try driving a nail into some hardwood by pushing down on it with a hammer.You would need a hell of a lot of weight to force it in. Then swing the hammer at it. Inertia is a wonderful thing when used to your advantage.
Though I think on a bike trying to keep things smooth and controlled the EV should have a big advantage in controlling how the power is delivered at all times helps for a smooth controlled run with power to the ground vs wheel spin.
offgridQLD wrote: One of my favorite examples of how savage it can be off the line (watch his left foot on the clutch)Image https://www.youtube.com/watch?v=qAo95Z7MPpw
If that thing had tits before hand, it doesn't now! The were definitely revved off.
offgridQLD wrote: Though I think on a bike trying to keep things smooth and controlled the EV should have a big advantage in controlling how the power is delivered at all times helps for a smooth controlled run with power to the ground vs wheel spin.
Exactly, while that big clutch dump helps get thing moving it also immediately put you into let's spin the wheels territory that is not good for consistent racing.
Also no big dump means you can turn the controller up more since there is no shock loading on the components, and they will last a lot longer.
Post by mikedufty »
There have been some interesting discussions in electric trials motorcycles forums on the merits of clutches. Some people considering installing a clutch to get that jump. I think some of the production models have a virtual clutch similar to the lock out button suggested above, it just allows you to go instantly to full throttle.
I always wonder how much of the soft take off in the i-MiEV is programmed in. My oset kids electric trials bike has a pretty savage response (in so far as 600w can be) I guess it is pretty low geared though.
The zero ds has a pretty soft takeoff too compared to an ICE bike with a clutch, but looking at videos of unintentional wheelies on their lower powered FX trail bike you wonder again if they've done that deliberately on the road bike to reduce wheelies, or is it just taller gearing?
Personally I like having to be careful not to wheelie.
"always wonder how much of the soft take off in the i-MiEV is programmed in."
I would say most of it. If you look at the power meter on the dash or through the OBD port and canion. You can see if you nail it from a stop or slow speed the power is limited as the needle swings to the right so slowly. If it was just due to tall single speed gearing and not soft starti the controller then the power meter would still peg to the right and it would turn to heat vs motion.
It's one hell of a fairy floss soft start they came up with on the Imiev.
Interesting outcome regarding the clutchless lectric trials bikes.
offgridQLD wrote: "When I let my clutch out I have reciprocating mass to help carry me off the line with an EV you may have peak torque but you don't have anything previously spinning.
The clutch dump is only of value in low torque engines, high torque engines actually use a slipper clutch to dump power off the line in an attempt to maintain traction. It is a whole science of reading the track to determine just how much clutch to apply to keep the vehicle accelerating in a straight line, even slight wheel spin means a trip into the fence. the Prostock cars are a great example of this but the biggest of them all is the nitro rails and funny cars, that clutch doesn't take up till half track sometimes. Being able to program in that reduced torque would make track tuning a science of the future, the driver does not have that option of how far to plant the foot yet still remain consistent. I guess as far as dial your own racing the ET could actually be tuned into the controller, that would take a lot of the driver and team judgement out of the sport effectively wrecking a great class of racing... something to be sorted in the near future I guess.
you could even go to the extent of having a light censer that will launch it when your light go's green lol
Adverse Effects wrote: you could even go to the extent of having a light censer that will launch it when your light go's green lol
No most classes of racing prohibit that. Electronics crept into drag racing years ago with a thing called a delay box. https://en.wikipedia.org/wiki/Delay_box which started all sorts of new rules to be made (I remember doing grudge nights in my Monaro around that time) basically it caused a big stink and people even in lowly street bracket racing categories got accused of cheating, and then people started hiding them to avoid detection.
Basically it got ugly and a ban was put on them at Willowbank, I don't know if it exists today.
You want to be leaving the line as the power goes to the green light, far too late once the light turns green, he who snoozes looses Image
No idea how they would determine if there was anything improper in the way a controller was programmed, I'm guessing there will be some noses out of joint once the big noise boys start getting flogged when they elect to go heads up racing in the finals    Image
Electric racing will be more consistent even without timing aids, by virtue of what it is. You are in the digital domain to start with.
Then you have the added benefit of no clutches or torque converters to content with, no having to make sure the revs are the same every time.
We are at an advantage to begin with, no rpms and maximum traction, virtually same conditions for every race.
bga
Real Name: Bruce Armstrong
Post by bga »
With respect to I-Miev slow initial acceleration.
I suspect that all of it's programmed.
Makes sense to prevent parking lot collisions, but is a trap for the unwary on the road. I put this down to Mitsubishi being too cheap to install proximity (parking) sensors that could have triggered this behaviour.
https://m.youtube.com/watch?v=qUlt_2Z1ubc
think this might be the best onboard video of Voltron I've ever uploaded!
Keep an eye out for Taz's massive wheelie down the start finish straight on lap one :mrgreen:
New lap record of 1:15.481 at Queensland Raceway and for the first time ever, we were allowed to race in a national series with gas bikes. We only did 4 laps while the gassers did 8, but the potential is clear.
Also, check out the live feed of the race here: http://livestream.com/itvl/events/6376399 and skip ahead to 4:17:00 for the race.
On the top screen skip to 4:17:00 for race 5 (same as the onboard footage).
She's pretty close to the limit with the current setup, so next step is to add a steering dampener and eventually put some decent fork internals in there. We'll sit out 2017 so we can develop a bigger battery capacity yet still have the same mass as currently there- 212 kg.
Well done Taz, impressive stuff.
And on the supject of clutches, the 6 race starts we did were all pretty good for us without one :)
Great stuff! Thanks Doctor Jones.
evric
Real Name: Eric
Post by evric »
Congratulations Chris and Taz.
Sutho
Real Name: Brett Sutherland
Post by Sutho »
Nice one Chris!
Sutho wrote: Nice one Chris!
Thought it might've reminded you of the Radical's start - see ya later, I'm up front Image
Last race of the season.
