gtyler54
Real Name: George Tyler
Post by gtyler54 » Fri, 15 Aug 2014, 13:00
It should be possible to make a device that sets the SOC in any way you like. It seems like a simple thing to do. I am an electronic design eng by trade, my limitation is I had a stroke, not paralysed or anything like that, but my brain gets tired quickly. I have 4 of these cars, I bought them to play with, but have since put new Toyota batteries in 2 of them as I ran out of energy. you are inspiring me to carry on with it however!
gtyler
Post by antiscab » Sun, 17 Aug 2014, 06:01
I am more an electrical eng - making a micro to send out the right signal is presently outside of my skill set (and most likely I lack most of the required tools)
I wonder if it would be possible to write a computer program to test the theory first, before making a prototype?
2017 Renault zoe
2007 vectrix - 145'000km
Post by antiscab » Mon, 01 Sep 2014, 02:02
Well, I tried driving around with my laptop plugged in Running TECU scanner
at first I was just looking at pack voltage and how well balanced the individual 5 groups of cells were from a voltage sag perspective - they were all pretty much the same :D
Then I tried resetting the SOC to 100% 2 or 3 times a minute
that yielded good results - the car started actively trying to discharge the battery (and the MFD lied like a politician about it)
fuel usage fell from an average of 5.4L/100km to 3L/100km
however, the laptop stopped communicating with the car half way through, so that value may fall further
I also need to start measuring how much energy the car is discharging from the battery, *and* I will need to start recharging the battery from the mains
Next proof of concept will be to get the laptop to automatically update the SOC to 100% without me hitting enter all the time. also I will need it to stop doing that when a 5 cell group voltage drops too far
next after that will be to insert the original prius temp sensors into the battery (I hadn't considered this in the initial conversion)
voltage sag is an interesting one.
I have no real idea of the batteries actual SOC at the moment, I just know it's not full and not empty
voltage was being pushed up as far as 375V (@ 50A of regen) and as low as 280V (@ 65A of discharge)
for a 100 cell 20Ah battery, it's not too bad, but given the frequency I think I will actually have to start looking into battery temperature rise
2017 Renault zoe
Post by antiscab » Mon, 01 Sep 2014, 02:56
Oh, I discovered using the TECU software that the highest SOC value that can be set is "127"
that suggests to me that be value being sent is actually a 7 bit value (or one byte with one bit reserved for something)
curiously, the updated % on the TECU software only showed a maximum of 74.5%, while the MFD showed full
not sure if this is because the software crashed
2017 Renault zoe
gtyler54
Post by gtyler54 » Mon, 01 Sep 2014, 14:45
that's interesting, are you sure that 127 is all the car ECU can accept? how did you prove this? I know you never see below about 20% on the scanner too.
gtyler
Simon
Real Name: Simon
Post by Simon » Tue, 02 Sep 2014, 02:44
Thought that was normal behaviour for the MFD to show full with 75% SOC.
gtyler54
Post by gtyler54 » Tue, 02 Sep 2014, 12:58
It is I think. the display only shows 25% (orange), 50%, 75% and full, and these do not correspond to the real SOC of the battery.
gtyler
Post by antiscab » Wed, 03 Sep 2014, 00:28
gtyler54 wrote: that's interesting, are you sure that 127 is all the car ECU can accept? how did you prove this? I know you never see below about 20% on the scanner too.
I tried entering 128 and the TECU program came back with an error
but 127 worked
I'm actually not sure if 100 is 100%, and just entering 127 didn't cause the program to crash and act weird
entering both 100 and 127 resulted in SOC being changed to 74.5%
anyway, at 74.5% the car is actively discharging the battery, which is the desired outcome anyway
I'm starting the car tonight with a full charge and going for a bit of a drive to get more data
2017 Renault zoe
Post by antiscab » Wed, 03 Sep 2014, 08:45
testing has revealed a few more things:
I seem to be able to update the SOC in the car only once every few minutes - not sure if the limitation is in the car or the TECU software
I wasn't able to do a full drive with discharging the battery constantly as the car faulted out tonight - it has developed an leak to ground *sigh*
looks like I need to pull the battery apart again.
on the upside, I will be able to implement some mods to the battery box and install the temp sensors
2017 Renault zoe
Post by antiscab » Wed, 03 Sep 2014, 15:13
oh, another thing I discovered
even when the car thinks the battery is full and needs active discharging, it will still run the engine until it is up to temperature
the end result is the fuel economy until the engine is up to temperature has no improvement
2017 Renault zoe
gtyler54
Post by gtyler54 » Wed, 03 Sep 2014, 15:33
I did compare start up performance to a charade. I was working at Gallaghers (electric fence people) and lived about 3km from there. close, but could still take 15min due to traffic. in winter the Prius had just got up to temperature as I switched off at work, consumption was 10L/100km. this is with the trip taking 5 min. I decided that it would be no improvement over a non-hybrid car, so used my Charade I had bought for an electric conversion for a month or so. Consumption: 15L/100km! Prius still wins..... also, when the engine is cold it runs with retarded ignition and rich mixture. Autospeed has a mod on their site to fool the car into thinking is it warmer sooner, this improves consumption.
gtyler
gtyler54
Post by gtyler54 » Wed, 03 Sep 2014, 15:38
antiscab wrote: testing has revealed a few more things:
by temperature sensors do you mean the 8 thermistor beads thay come out individually, or the thermistor strips with thermistors at each cell? (i.e. 240 thermistors)
gtyler
Post by antiscab » Wed, 03 Sep 2014, 20:06
gtyler54 wrote: when the engine is cold it runs with retarded ignition and rich mixture. Autospeed has a mod on their site to fool the car into thinking is it warmer sooner, this improves consumption.
That's interesting, I will have to look into that
Just the 8 thermistor beads
The thermistor strips I just faked out with a few 280 ohm resistors
Also - wiring fault corrected and car is running ok again - luckily the fault was easy to get to.
the temp sensors will have to go in another time
2017 Renault zoe
gtyler54
Post by gtyler54 » Thu, 04 Sep 2014, 03:12
one warning about the autospeed article - it says the connections to the engine ECU is the same as the NHW11, I don't think that's right. you can trace it from the temp thermistor, connector between engine and inverter (green and black wires)
gtyler
Post by antiscab » Mon, 08 Sep 2014, 07:02
lately I have just been driving around with a laptop, manually resetting the SOC every few seconds
here's my present observations:
using the TECU software, the more values you ask it to display, the slower the program runs.
If you want to update the SOC quickly, you should only poll for one or two values (in my case I choose pack voltage and current)
while SOC is very high, the car will run battery only as long as you stay below 50kmh and below 35A
I was able to use 5.5Ah on a 30km drive - by doing 50kmh most of the way
The engine does eventually restart when it gets too cool
I am now wondering if there is a long term wear and tear issue with doing 50kmh continuously, as MG1 is spinning at near it's max rpm (10'000rpm)
While the engine is running, the car will still discharge the battery at 10-15A continuous, when SOC is set very high.
I'm not sure if running this way is particularly efficient - I'm not sure how to measure this
2017 Renault zoe
gtyler54
Post by gtyler54 » Mon, 08 Sep 2014, 15:35
"While the engine is running, the car will still discharge the battery at 10-15A continuous, when SOC is set very high.
I'm not sure if running this way is particularly efficient - I'm not sure how to measure this"
At times the engine is just turning over with no petrol supplied, I think that is what is happening here, while it is drawing 10A. one reason it does this is to keep MG1 revs down at higher road speeds, as you obviously know from your post.
I want to remove the engine and replace it with a one way clutch, like a bendix from a truck starter maybe. this will let MG1 add it's torque at lower speeds but still not overspeed at 100+ km/hr.
gtyler
Post by antiscab » Thu, 11 Sep 2014, 01:33
gtyler54 wrote: At times the engine is just turning over with no petrol supplied, I think that is what is happening here, while it is drawing 10A. one reason it does this is to keep MG1 revs down at higher road speeds, as you obviously know from your post.
at 50kmh with the engine off 25-35A is drawn from the battery
at 60kmh and above, with the engine on, 10-15A is drawn from the battery - so definitely using fuel, I'm just wondering if the engine is operating at an efficient load (peak efficiency for this engine is 38% at minimum load of 10kw (WOT 1000rpm))
For MG1 to add torque, you will need a motor on the motor input - just adding a clutch and disconnecting the engine will just result in the engine output spinning up, with no net torque applied to the wheels
I just found this
auto keyboard program
This will allow me to drive while not having to keep hitting the enter key on my laptop
I just put a full tank of fuel into the prius.
I will be able to report back in a few weeks what the economy is like (L + kwh/100km) now
2017 Renault zoe
gtyler54
Post by gtyler54 » Thu, 11 Sep 2014, 02:08
my thinking with the clutch is this:
1) at low speed MG1 drives power split device, clutch is enguaged, so other side of PSD (where engine would be normally) is held stationary, MG1 can drive.
2) as speed increases MG1 RPM reaches max, it then can't add torque past this RPM, so it stops. clutch freewheels.
gtyler
Post by T1 Terry » Thu, 11 Sep 2014, 03:55
I think you are referring to a sprag clutch, similar to that used in an automatic transmission torque converter to allow the stator to lock at low eng rpm but free wheel as the rpm increases. This is how the torque multiplication functions at low speed yet doesn't restrict higher eng revs.
Post by antiscab » Thu, 11 Sep 2014, 06:18
ah ok, I see what you guys mean
ok, latest news
I went for a drive today - newest revelation - the car will in fact drive with the engine turning but no fuel usage - above 50kmh, and up to 35-40A
I drove for 50km and used 10Ah from the battery, all at speeds below 70kmh
MFD showed above 30km/L for over 30 mins
engine only ran on accelerations, and promptly shut down once power needed was below ~11kw
this was with SOC being reset to 100% every 30 seconds
bad news is the ground fault is back.
either I didn't fix it properly, or there's another one :(
2017 Renault zoe
Post by antiscab » Thu, 11 Sep 2014, 06:48
seeing how well the car ran before the ground fault cropped up again has prompted me to start looking for more NHW10's
here's what I have found so far:
tasmania
gympie QLD
Ararat VIC
Reservior
None in Perth sadly
I remember a guy in lynwood or maddington having a couple for sale
does anyone know what became of those?
2017 Renault zoe
7circle
Real Name: Ken
Post by 7circle » Fri, 12 Sep 2014, 02:19
Just thinking of the unsold cars where the motors and drive systems getting scrapped Image
Post by antiscab » Fri, 12 Sep 2014, 04:58
7circle wrote: Just thinking of the unsold cars where the motors and drive systems getting scrapped Image
I know :(
I feel kinda guilty it's taken me 2 years to get to this point - I wonder just how many NHW10's have been lost in this time
2017 Renault zoe
Post by Adverse Effects » Fri, 12 Sep 2014, 08:34
I know :(
to many but that would be partly because there are a lot of people out there that think along the lines of if someone dont want to pay me what i think its worth i'll just crush it insdead of someone else getting a good deal
like the problem i am having at the moment
just below the windscreen of your car there is a steel panel that your wipers mount to, mine has rusted away the wreckers wot sell me it for less than $250 (and i was going to do all the work to get it out or it would have been $450) i told him i wouldn't buy it at that price and i stood there when he told the fork lift guy to take it to the crusher (about $5 in scrap metal price is all they would get for it after that)
Last edited by Adverse Effects on Thu, 11 Sep 2014, 22:37, edited 1 time in total.
Post by antiscab » Sun, 14 Sep 2014, 02:08
more updates:
I'm not sure my cycle analyst Ah count is accurate
I tried to use one of my kwh counters to measure how much the charger consumed on recharge - but it only showed 0.5kwh used, while the cycle analyst shows 10Ah discharged (@330v)
biggest news:
at some point if you drive long enough the battery actually gets empty.
when this happens, if you keep telling the car SOC is 100%, but it sees one or more voltage blocks voltage collapse, it flags the battery as bad and fails with the no longer driveable.
this happened to me today,
I thought my earth leak was back - but I had no error codes indicating that was the case :s
resetting the SOC to 0% corrected everything
I have asked a friend to look into making a gizmo that keeps resetting SOC to 100%, while polling for the lowest block voltage. when lowest block voltage falls to a certain voltage, SOC resets to some low value.
2017 Renault zoe
