Obsolete Thread
- EV2Go
- Real Name: Paul
- EV2Go
- Real Name: Paul
- EV2Go
- Real Name: Paul
- EV2Go
- Real Name: Paul
- EV2Go
- Real Name: Paul
- Electrocycle
- Real Name: Andrew
- MSN: dumhed@dumhed.com
it seems to work, and apparently reduces dive under brakes
- EV2Go
- Real Name: Paul
- Electrocycle
- Real Name: Andrew
maybe the forks are just dampers?
Changing the trail under compression might be a good thing - if it's done right.
It could also be an extra complex way of achieving the same result - classic BMW!
- Real Name: john
the top yoke is exactly the same as a normal fork set up with the bars mounting normally there is no bottom yoke just the a arm which connects to the sliders via a ball joint when the brakes are applied the anti dive comes in and locks the suspension so there is no travel only when going over bumps in normal riding conditions which doesnt matter much so the set up is better than slider type forks which dont have anti dive its the same as the old honda step-thrus and does take a bit of getting used to to prevent skipping
- gholm
- Real Name: James Neale
Hey ev2go, just curious as to how you plan to cool your motor, and whether you still plan to lop off the non-drive shaft on the fan end.
Let me know, I'm using my Kostov with its fan and it's very loud when at speed. I gathering ideas for an electric thermo-controlled jobbie and was wondering about your intended approach.
(I don't want to chop off my excess shaft though:)
The J2EV :
http://www.evalbum.com/3457
- EV2Go
- Real Name: Paul
- gholm
Not sure which one I have actually.
Mine has a silver fan cover rather than a yellow one if that's any indication (?)
The J2EV :
- EV2Go
- Real Name: Paul
Just wondering what would be the EMP of a Kostov on your nuts been that close? Is it a concern? Also just wondering have you thought about using MR10 or similar shatterproof scratch resistant Lexan in a tint of your choice? that way you can see all the wonderful frame and electrics like a Jellyfish under the deep ocean, even some LEDs can be stratigically placed so they can be changed to any colour you choose as you cruise with a knob on your dash or a program for multiple change mode. Would make everyone see things differently as I believe we should do everything we can to use electricals to convince non-EVolved thinkers.
- Richo
- Real Name: Richard
I saw them advertising electromagnetic therapy on TV yesterday for one of those 6:30pm time slot news programs.
Seems to help with join pain etc.
NOW everyone wants to live under the powerlines
Based on this theory I see eV's in the future curing cancer
- EV2Go
- Real Name: Paul
It was on some show, there is some kind of paint that is used in Germany due to their studies on EMP everywhere in metro areas, but Im sure there are other ways to stop the nuts from over roasting
- EV2Go
- Real Name: Paul
You can also use medieval armoured cod piece
- EV2Go
- Real Name: Paul
- EV2Go
- Real Name: Paul
- Real Name: Glenn Marks
EV2Go wrote: Took some photos of a BMW at work... Ok is it just me or is there something fundamentally wrong with this design?
I suspect when the front dips under breaking the front wheel pushes forwards as it traverses the ark (you are speeking about) thus keeping the same angle on the forks (more or less) under breaking as it has in normal stance. Just a guess based on what I see.
What batteries are you thinking of using now?
Glenn
Regards
Glenn Marks
Glenn Marks
- EV2Go
- Real Name: Paul
do you have a URL where I can go to look at specs for these batteries?
Google brings up nothing and I can't find them on the A123 web site?????
What is the top blue bar for on tour swing arm? I see the bottom one is to allow tilting.
Glenn
Glenn
Regards
Glenn Marks
Glenn Marks
- EV2Go
- Real Name: Paul
