Page 10 of 24
EV2Go's - Lithium Powered Trike
Posted: Fri, 26 Nov 2010, 16:40
by Renard
In my experience, fixing various appliances, pulling 10A from a 10A outlet with a 10A plug leads to burnout eventually. Better to use a 15A plug and socket for currents near 10A.
Posted: Fri, 26 Nov 2010, 16:53
by EV2Go
Posted: Fri, 26 Nov 2010, 17:13
by Renard
Yes, 10A equipment will work, but not for ever. Make sure the plug/socket mating is clean and firm. It should give you a few years.
Posted: Fri, 26 Nov 2010, 17:21
2400W fan heaters are a good indication of how well it will go. As Renard suggest you may need to replace the lead and the power point after a year or so. Use a brand new power point and never let anyone plug any dirty leads into it - EV ONLY!
Posted: Fri, 26 Nov 2010, 21:01
by EV2Go
Posted: Fri, 26 Nov 2010, 21:27
by EV2Go
Posted: Fri, 26 Nov 2010, 22:13
by Speedily
what,no tyre paint first
very nice polishing job haven't seen to many wheels that sparkly
Posted: Fri, 26 Nov 2010, 23:10
by EV2Go
Posted: Sat, 27 Nov 2010, 20:42
by EV2Go
Posted: Sun, 28 Nov 2010, 03:57
by 7circle
Just a thought on keeping sunlight away from the metal live suspension torque torque tube if you go that way.
There is a possibility of a lot o metal holding the motor tho the rear axle.
That could be used for keeping the motor cool, like a big heat sink with air rushing over it.
Sunlight shining on the metal frame could raise it to be very hot to touch.
Your likely to have it covered and the main frame surrounding it.
But thought it was worth mentioning... QLD is suppost to be the sunshine state.
7© Ken
Posted: Sun, 28 Nov 2010, 04:52
by EV2Go
Posted: Sun, 28 Nov 2010, 06:17
by EV2Go
Posted: Sun, 28 Nov 2010, 07:40
by EV2Go
Posted: Sun, 28 Nov 2010, 10:39
by T1 Terry
Just another thought, have you looked at the VW rear torsion bar set up? no axle twist possible and some softening of the rear end for kidney longevity. You could pick up a rear torque tube assembly from a wreckers cheap and cut it down to size.
Posted: Tue, 30 Nov 2010, 03:06
by Electrocycle
You need to hurry up with this trike
I built one in a day and won a race with it on the weekend!
http://www.youtube.com/watch?v=iD1leKEwng4
Posted: Tue, 30 Nov 2010, 03:26
by T1 Terry
I wasn't quite sure how you were going to pass him till he spun out, that looked like a lot of fun. Loved the helmet cam, well done.
Posted: Tue, 30 Nov 2010, 03:38
by Electrocycle
yeah I passed people easier on the earlier runs, but without a push start the extra weight of mine was a bit of a disadvantage!
Posted: Tue, 30 Nov 2010, 04:26
by EV2Go
Posted: Tue, 30 Nov 2010, 04:36
by Electrocycle
In a word, yes
http://www.youtube.com/watch?v=6zq_k8Q0sc4
It was very stable, but if anything the front end was too light. Most of the pushing was due to braking too hard into the corner, or the wheel jumping over rocks.
On decent ground the front end is very responsive.
Weight distribution is about 60kg rear and 25kg front with no rider.
Difference between having suspension on the front but not the back?
http://www.youtube.com/watch?v=aZkpr25mLq8
Posted: Tue, 30 Nov 2010, 13:49
by Gow864
Great vid EC!!! I loved the front wheel sliding into those corners. What a HOOT!!!
Posted: Tue, 30 Nov 2010, 14:42
Great fun!
Posted: Wed, 01 Dec 2010, 20:09
by elconcharger
Paul, thanks so much for the post. Everyone here can learn more about TC chargers.
EV Power (
www.ev-power.com.au) stocks a range of TC Chargers for resale
in Australia. Please contact them if you require just one or two units
and they will do their best to help you. Rod Dilkes Cell 0428 321 865
Posted: Thu, 02 Dec 2010, 00:42
by EV2Go
Posted: Thu, 02 Dec 2010, 05:22
by 7circle
Hows the layout going.
Your earlier chassis layout with seat, handle bars, front wheel and rear wheel loactions are the base. Maybe you need to add virtual iPaul to show rider position.
Looking at my cars rear suspenssion it gets complicated under there.
I would like to see your suspension with shock absorbers too.
The forces on the mounting points are very large too.
Side latereal motion and eliminating stresses through the motor need to be considered too.
Have a look at this on ebay. They show what it could turn into in the extra pics
NEW TRIKE SOFTAIL CHOPPER FRAME ROLLING CHASSIS HARLEY
OR this V8 Beast to compete with
Also the GTM trikes have lots of info on chassis construction.
But they are for more passengers.
Look forward to seeing more on the chassis design.
Posted: Thu, 02 Dec 2010, 19:11
by EV2Go
