I wanted a fairly light car, with rear wheel drive so as to eliminate the gearbox and one that wasn't too expensive. A 1988 BMW 318 for $500 fitted the bill nicely. In pretty good nick except for no WOF and no Rego, plus needing 4 new tyres, but mechanically sound with new brakes and shock absorbers.
Early on I decided PbA was a waste of time, Li is the only way to go! Also, I planned to go with ac but eventually decided it was a bit hard and couldn't find an affordable controller of a reasonable size, so went with dc - for now, anyway.
The transmission tunnel of the BMW isn't large enough for a big motor, so I decided to use two smaller ones coupled together. The Advanced L91 is my motor of choice.
Here's the car ready for "extraction"!
It took a while to remove that lump of metal, but it eventually came out to leave a nice, gaping hole. The motor and (auto) gearbox together, plus the exhaust system, fuel tank and radiator weighed in at 236 kg, All that dead weight - gone!
Now to figure out how to put something back in there.
Quite exciting when the motors arrived, here's what one looks like. It weighs 37 kg:
I built a dummy frame out of MDF to get the fitting and dimensions worked out. The cast Al bracket on the end is the BMW gearbox mount crossmember:
Coupling the two motors together puzzled me for a little while, as a commercial flexible coupling was very expensive and also quite large in size. But the BMW uses a rubber doughnut to couple the gearbox to the front drive shaft, so I thought one of those could be modified to do the job. A trip to the local wrecker gave me a rubber doughnut and a couple of front drive shaft sections that I could cut the 3-prong "spider" from, and my mate with a machine shop turned them up, drilled them out and cut keyways to make a very satisfactory coupler. Here it is fitted to the motors in the final Al mounting frame:
The motor frame itself is a work of art! Made from 10mm Al plate, cut and curved and welded, an engineering masterpiece made by a true craftsman! Not me, a fellow I have come to know quite well who has an engineering business just down the road. He hasn't sent in the bill yet, so we are still able to afford to eat!
Fitting the motors and the coupling was quite an intricate task and took me most of a day as I had to get the motor shafts aligned to a high degree of accuracy. The flexible coupling can handle angular displacements, but I thought it would struggle with co-axial offsets. Anyway, the removable mounting plates are designed to take small shims to be able to correct any mis-alignment and I managed to get it to better than .2mm which I thought would do quite well.
And another view:
You can see the reversing and second motor isolating contactors, the LogiSystems controller and the way the two motors fit together. The long channel sections are the front mounts which go onto the original BMW rubber engine mounts.
The "second motor isolator" allows me turn off the power to one motor. I thought this might make a useful "Power/Economy" selector and also will turn off one motor when in reverse. I don't need 100 kph going backwards!
Here's the "gearbox" mounting end of the frame assembly showing the part of the coupling that will attach to the BMW drive shaft:
Yesterday, I finished wiring the motors and contactors, all with 70 sq mm cable, and applied a 12V battery to it to see what would happen! The motors rotated beautifully, with no vibration that I could feel, proving that my motor alignment is pretty good. Big sigh of relief!
These motors are capable of around 47 kW of power and 216 NM of torque - each! The LogiSystems controller can deliver up to 1000A which is 150 kW from my 150V battery pack (ignoring the fact that it would sag mightily at that current) so I expect pretty good performance from this thing.
The Sky Energy cells are here and I have 135 of them. They are 40 AH cells and I am going to connect them as 45 series blocks of 3 in parallel. ie effectively 45 120 AH cells. I didn't use 120 AH cells as they are too tall to fit where I plan to put them.
I tested some of these at 120-odd amps discharge and measured a capacity of typically 46 AH, so I expect my battery pack to store 3x46x45x3.2 = 19.87 kW-hrs. That means I have 16 units of electricity available if I discharge them 80%. Might take me 100 kms!
Next job is to give the BMW engine bay a good clean and then fit the motor frame. Watch this space!
