Classic EV Conversion - Daimler 250 (V8)
Daimler
Real Name: Andrew Clarke
Post by Daimler »
Hello to the Forum.
I drive a 1968 Daimler 250 V8 almost identical to this one:https://www.shannons.com.au/auctions/20 ... BN179LAE5/.
At least I did until recently when the engine finally died.
Rather than jumping into replacing the motor with something the same or similar, I thought I should at least explore the feasibility of doing an EV conversion.
The car has a kerb weight of about 1300kg (with the current engine).
I am entirely new to this and suspect it may be unrealistic for me.
If anyone has the time and knowledge to answer a few questions I would be sincerely grateful.
1. I am reasonably handy but not a mechanic nor an electrician. (I can build and fix things.) How much of the work could I possibly do myself?
2. What kind of a set-up would you recommend? I’d like to have a 150+km range if possible and some get-up-and-go?
3. Could my existing automatic transmission marry with the electric motor?
4. Is there a DIY manual/job list for doing a conversion?
5. What about things like powering the existing power-steering, providing a de-mister for legal requirements, and any other bits and pieces I would need to know about? What happens there?
6. How far would a budget of $10,000 go?
7. Approximately how long would this kind of project take? (I need to get back on the road ASAP.)
8. I live in Toowoomba, QLD. Is there any local enthusiast who might like to guide/help/become my new best mate?!
I look forward to any feedback anyone can give.
If you are just laughing and rolling your eyes and want to tell me to forget about it, that’s fine too. I need to know.
With sincere thanks,
Daimler
(Andrew)
jeffthewalker
Real Name: Jeff Johnson
Re: Classic EV Conversion - Daimler 250 (V8)
Post by jeffthewalker »
Daimler wrote: Mon, 13 Nov 2017, 08:36
Daimler
(Andrew)
Link to meeting details viewtopic.php?f=43&t=5365
Get to the Brisbane meeting this coming Wednesday evening if you can. Lots of conversions been done by the members and they love talking about it.
Jeff
Daimler wrote: Mon, 13 Nov 2017, 08:36 Hello to the Forum.
Hi Andrew - Welcome!
Daimler wrote: Mon, 13 Nov 2017, 08:36 The car has a kerb weight of about 1300kg (with the current engine).
The weight is not really any different to a new 4-door sedan.
The issue may be Gross vehicle mass (GVM) - which may not even have a listing for your car.
Daimler wrote: Mon, 13 Nov 2017, 08:36 1. I am reasonably handy but not a mechanic nor an electrician. (I can build and fix things.) How much of the work could I possibly do myself?
I am sue if you cant there maybe some that can - go to the AVEA meeting as suggested.
Daimler wrote: Mon, 13 Nov 2017, 08:36 2. What kind of a set-up would you recommend? I’d like to have a 150+km range if possible and some get-up-and-go?
150km may mean you need a 30kWh pack which is quite large for a conversion.
The original 2.5L V8 had 106kW (supposedly) so there should be a few motors and controllers to choose from.
An 11" DC system would probably be fine.
Daimler wrote: Mon, 13 Nov 2017, 08:36 3. Could my existing automatic transmission marry with the electric motor?
It could but isn't usually worth the effort.
More common it to ditch it and have a custom drive shaft for direct drive.
Less losses and less to go wrong.
Daimler wrote: Mon, 13 Nov 2017, 08:36 4. Is there a DIY manual/job list for doing a conversion?
Ah NCOP14 would be a place to start otherwise keep asking questions here.
Daimler wrote: Mon, 13 Nov 2017, 08:36 5. What about things like powering the existing power-steering, providing a de-mister for legal requirements, and any other bits and pieces I would need to know about? What happens there?
So usually it is the case if it had it before it should have it after.
You'll also need a vacuum pump for the brakes.
Either replace the power steering rack with an electric one or fit an additional motor to the pump.
A water heater and small pump can be placed in the engine bay to keep the interior heated.
Or gut the vent unit and replace with a ceramic air heater.
Traction Fuses, contactors, BMS are some other parts.
Daimler wrote: Mon, 13 Nov 2017, 08:36 6. How far would a budget of $10,000 go?
Not far.
If your lucky that might get you 25kWh of batteries - that's 5kWh less than your desired range.
Wouldn't include anything else :shock:
You'll need like $6,000 just for a motor and controller.
Daimler wrote: Mon, 13 Nov 2017, 08:36 7. Approximately how long would this kind of project take? (I need to get back on the road ASAP.)
Well if it's like me and have a million things to do - for ever :lol:
If you were dedicating 100% of your day to it perhaps 3-4 weeks.
Daimler wrote: Mon, 13 Nov 2017, 08:36 8. I live in Toowoomba, QLD. Is there any local enthusiast who might like to guide/help/become my new best mate?!
Answered above...
Daimler wrote: Mon, 13 Nov 2017, 08:36 If you are just laughing and rolling your eyes and want to tell me to forget about it, that’s fine too. I need to know.
No I think it's worth it.
It's all possible - you just need the Mula and time and a willingness to do it.
Easier with a classic;
If there was a Daimler 250 model without fancy things like brake booster, power steering, heater/demister then you can hopefully do without them to reduce complexity.
Take a look at the converted cars at the Brissy meeting; similar (front engine + RWD) layouts would include Weber & Coulomb's MX-5.
